Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Off Topic
Old 06-14-2009, 10:23 PM   #1
Blisters
I was using pliers to pull a couple thousand long staples out of a subfloor a couple nights ago. Now I have a big blister on two fingers.
Is it true that you shouldn't drain the fluid from a blister?
gma2rjc is online now   Reply With Quote
Old 06-15-2009, 12:12 PM   #2
47_47's Avatar
Blisters
I heard that you shouldn't, but I still drain blisters.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Old 06-16-2009, 04:11 PM   #3
gravity always wins
Blisters
Well, I've noticed that if I don't pop them, the new skin underneath will get a chance to toughen up first. Most times, I end up popping them accidently while I'm working and then they hurt like hell.
Old 06-16-2009, 05:51 PM   #4
Blisters
My 2 cents, I sometimes pop them but never ever rip that skin off, that raw stuff underneithe will be very tender.
And, I think this is a wonderful opportunity for you to pop it and then post the results, it will be brand new data
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 06-16-2009, 05:55 PM   #5
the Musigician
DangerMouse's Avatar
Blisters
i drain it, and push the skin back in place and put a bandaid on it, it'll grow right back together...
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 06-16-2009, 06:06 PM   #6
Blisters
Brand new data? lol
You're right about leaving the skin on.
I had one of them break while I was still pulling staples. It felt fine the next day.
The other one that didn't break was sensitive until it finally broke (while using a shovel in the yard).
Conclusion: Keep working until they break. Better yet......wise-up and wear some work gloves. LOL
Old 06-16-2009, 06:09 PM   #7
Blisters
That would be better than peeling the skin off.
Old 06-17-2009, 07:18 AM   #8
gravity always wins
Blisters
Even better: avoid work that causes blisters. Use power tools. I never got a blister from a power tool. Other injuries, yes. Blisters, no.
Old 06-17-2009, 08:06 AM   #9
Blisters
A blister is your bodys band aid, the fluid protects the fresh skin underneath. Don`t pop them and stop when you see one because the next level is tearing the fresh skin underneath and bleeding.
Chemist1961 is offline   Reply With Quote
Old 06-17-2009, 08:29 AM   #10
the Musigician
Blisters
i pop them BECAUSE of that reason, it'll surely snag and rip open if i don't secure it.... but that's just my luck, not everyone's.... or iS it?
DM
Old 06-17-2009, 09:14 AM   #11
Blisters
I took the skin off of both of them this time. Only because I was planting some flowers outside and dirt got inside one of them and I couldn't get it out.
Old 06-17-2009, 09:16 AM   #12
Blisters
i just put in 1000 deck screws using a hand drill - and I have a huge one between my thumb and finger from gripping the drill !
stephen44 is offline   Reply With Quote
Old 06-17-2009, 09:41 AM   #13
Blisters
Here's what stinks. Once you notice a blister starting, there's nothing you can do to keep it from getting worse.
What ever job you're doing, you can't stop in the middle of it because of a blister. You have to keep going until the job is done.
I tried switching hands and pulling the staples out of the floor using the pliers in my left hand. That didn't work. There isn't as much strength in my left hand.
I can imagine it wouldn't work for you trying to drill screws in with the hand you don't typically use.
Old 06-17-2009, 10:12 AM   #14
Blisters
you're right - it was 90 degrees here as well - and i just don't get on with gloves in that heat !
I have found that liquid skin (it's like super glue) works real well to keep it dry and clean once broken !
Paint bubling and blistering sledhead41 Painting 12 05-28-2009 08:14 PM
Paint Blisters Malibujim Painting 5 05-12-2009 09:49 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
New Roof needed .....only 8 years old!!! unhandy7 Roofing 9 11-18-2005 04:52 PM
