-   Off Topic (http://www.diychatroom.com/f39/)
-   -   Blisters (http://www.diychatroom.com/f39/blisters-46646/)
gma2rjc 06-14-2009 09:23 PM
Blisters
I was using pliers to pull a couple thousand long staples out of a subfloor a couple nights ago. Now I have a big blister on two fingers.
Is it true that you shouldn't drain the fluid from a blister?
47_47 06-15-2009 11:12 AM
I heard that you shouldn't, but I still drain blisters.
Maintenance 6 06-16-2009 03:11 PM
Well, I've noticed that if I don't pop them, the new skin underneath will get a chance to toughen up first. Most times, I end up popping them accidently while I'm working and then they hurt like hell. :huh:
DUDE! 06-16-2009 04:51 PM
My 2 cents, I sometimes pop them but never ever rip that skin off, that raw stuff underneithe will be very tender.
And, I think this is a wonderful opportunity for you to pop it and then post the results, it will be brand new data :thumbup:
DangerMouse 06-16-2009 04:55 PM
i drain it, and push the skin back in place and put a bandaid on it, it'll grow right back together...
DM
gma2rjc 06-16-2009 05:06 PM
Brand new data? lol
You're right about leaving the skin on.
I had one of them break while I was still pulling staples. It felt fine the next day.
The other one that didn't break was sensitive until it finally broke (while using a shovel in the yard).
Conclusion: Keep working until they break. Better yet......wise-up and wear some work gloves. LOL
gma2rjc 06-16-2009 05:09 PM
That would be better than peeling the skin off.
Maintenance 6 06-17-2009 06:18 AM
Even better: avoid work that causes blisters. Use power tools. I never got a blister from a power tool. Other injuries, yes. Blisters, no.
Chemist1961 06-17-2009 07:06 AM
A blister is your bodys band aid, the fluid protects the fresh skin underneath. Don`t pop them and stop when you see one because the next level is tearing the fresh skin underneath and bleeding.
DangerMouse 06-17-2009 07:29 AM
i pop them BECAUSE of that reason, it'll surely snag and rip open if i don't secure it.... but that's just my luck, not everyone's.... or iS it?
DM
gma2rjc 06-17-2009 08:14 AM
I took the skin off of both of them this time. Only because I was planting some flowers outside and dirt got inside one of them and I couldn't get it out.
stephen44 06-17-2009 08:16 AM
i just put in 1000 deck screws using a hand drill - and I have a huge one between my thumb and finger from gripping the drill ! :mad:
gma2rjc 06-17-2009 08:41 AM
Here's what stinks. Once you notice a blister starting, there's nothing you can do to keep it from getting worse.
What ever job you're doing, you can't stop in the middle of it because of a blister. You have to keep going until the job is done.
I tried switching hands and pulling the staples out of the floor using the pliers in my left hand. That didn't work. There isn't as much strength in my left hand.
I can imagine it wouldn't work for you trying to drill screws in with the hand you don't typically use.
stephen44 06-17-2009 09:12 AM
you're right - it was 90 degrees here as well - and i just don't get on with gloves in that heat !
I have found that liquid skin (it's like super glue) works real well to keep it dry and clean once broken !
