3-prong Recepticle - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 06-05-2010, 12:40 PM   #1
3-prong recepticle
Just curious,, it was mentioned around that when installing a 3 prong outlet, the "new" way was to point the ground hole upwards. I've heard its not officially code but you should do it that way when replaceing one. Point I'm trying to get across is that it seems with the design of power cords, this doesn't work right. I've seen plugs that are molded that dont' quite lay flat against the wall when placed "upside down". Curious about others take on this.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 06-05-2010, 03:48 PM   #2
If it aint broke don't fix it. I never seen anything wrong with the way it was.
Bushman is offline   Reply With Quote
Old 06-05-2010, 04:22 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
I prefer ground down in a residential setting, since yeah, lot of devices and plugs are design to go in better this way and I'm just used to seeing it that way. I did notice in commercial settings they often put ground up, and it's probably for that extra safety, but the odds of something falling perfectly between the blades is slim, and even with ground up, if that chance did happen, it can still hit the ground and hot if it falls at the right angle. Either way the odds are slim when things are plugged in properly.
If you REALLY want to be safe replace everything with twist lock plugs. J/K
Old 06-09-2010, 10:11 AM   #4
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
My parents house have a few the right way and a few upside down . Frankly I think it's just coincidence and the person installing them just did whatever was easiest.
I tried just for kicks - when I replaced all my old 2-prong ones, they wouldn't actually fit in the box upside down, only w/ the ground plug down.
CoconutPete is offline   Reply With Quote
4 prong 220v recep. to a 3 prong mopowers Electrical 12 05-03-2012 06:39 PM
changing 3 prong receptacle to 4 prong WendyS Electrical 12 01-17-2010 08:59 PM
Please help, changing dryer cord from 3 prong to 4 prong oldpirate Electrical 8 08-10-2008 04:42 PM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
3 prong 4 prong 240 ranges. K2eoj Electrical 1 11-21-2005 06:39 AM
