Wire Needed For 40gal WTR HTR? - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 06-03-2011, 10:50 PM   #1
Question
Wire needed for 40gal WTR HTR?
I will save my entire sob story- I am about to be a 1st time mom in 3 days, I got a place that the previous owners took the water heater.. and wire with them., i NEED HELP asap please!
I bought a 40 Gallon electric GE water Heater (model GE40MO6AAG), and idk what happened, but the breaker kept blowing, and I checked the water heater, and there are 2 metal plates on the side with the therm and reset button- the upper plate, had black water leaking from it, when i removed plate it looked like it had burnt. I got a new water heater- (same model)
I just desperately need to know what size/type wire is needed, and what size breaker I should have. The manual has no mention of this. If anyone can please guide me on the proper wire and breaker it would be GREATLY appreciated! I just want to be ableto give my new son a hot bath (and have hot shower myself) Thank you so much.
JennyBear29 is offline   Reply With Quote
Old 06-06-2011, 09:08 AM   #2
Rewards Points: 3,130
You should have a 30-amp, double pole breaker. The wire should be 10-2.
Old 06-12-2011, 07:43 PM   #3
Welcome to the site !
Best to ask questions in the electrical forum instead of the Introduction area
Search the GE site for install directions:
http://genet.geappliances.com/search...fields=*&q=40M
Tags
help please , water heater wire?
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 04:24 PM
6/3 wire through smurf tube? anygren Electrical 13 08-14-2010 07:23 AM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 10:44 AM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-14-2009 11:17 PM
