Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Introductions
Old 11-01-2009, 07:01 PM   #1
Default winwan
it is nice to hear from other people having same situations as mine. we own a new home in Seymour Ct. We have a sheetrock issue joints that are cracking and opening wider each day. any answers
winwan is offline   Reply With Quote
Old 11-01-2009, 09:15 PM   #2
Home Slave
Lazy_Jake's Avatar
"Any answers?"
Seems like the house is shifting or some support has been lost. How old is the house? What is the soil/ground/grade like around the house? Anyone else in the neighborhood experiencing this? It could be something as simple as poor workmanship like large gaps filled with putty. Or it could mean that part of your house has lost support due to rotting or poor support design. Worst case scenario would be the surrounding ground could be shifting or sinking. Unlikely, but possible.
I would investigate some more, but hopefully its as easy as a mudding and painting fix.
Lazy_Jake is offline   Reply With Quote
More On This Topic
Learn about applying putty to refinish a door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Learn tips for applying putty to door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Drug abuse has no respect for age, gender or status. It affects teachers, physicians, mothers and clergy. The impact of this disease can be far reaching and destructive for the addict and those close to him. Follow these steps to identify the problem and... Read More »
So say you did have to end up stopping in the middle of a hard strenuous climb because you, you know, spun out and lost traction or you just got too tired to keep going. How do you restart? First thing you do, is check to make sure that you're in a place... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
