Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Introductions
Old 11-03-2009, 02:09 PM   #1
Default Vinyl over steel siding
I have a home with steel siding and I have been told that you can hang vinyl siding over the steel siding is that possible????
lpblisa is offline   Reply With Quote
Old 11-03-2009, 09:06 PM   #2
ArmchairDIY's Avatar
My first thought is it would be difficult. But can you describe your steel siding or post a photo?
"It looked good on paper, but paper is funny that way"
ArmchairDIY
ArmchairDIY is offline   Reply With Quote
Old 11-04-2009, 12:30 AM   #3
rather than have to build the windows and door openings out--why not strip the steel siding off and scrap it for some $$. this way you start with a clean slate. maybe add some insulation or house wrap before the vinyl
In my opinion this would be a better way to go.
Why replacing the steel? Paint faded, bad color or dinged up? Steel siding can be repainted if it is just a color reason.
What have I done is offline   Reply With Quote
Old 11-04-2009, 07:21 AM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
the first thing that came to mind was, I would be concerned about the existing steel siding heating up and distorting the siding, are you going to install insulated backer that would help. I have seen a few jobs that oil canned from this. when installed on a trailer with steel siding. just make sure the siding can and has room to move from side to side. BOB
More On This Topic
Aright, this is it, the final thing, part of the process, this will clean the surface area a little bit and it will also even out the sheen, make it look a little better. You can use pretty much any product, any kind of furniture polish spray, a little... Read More »
Custom vinyl signs can cost a bundle, but you can make your own and save money. Use a vinyl sign kit to create a good looking sign to advertise your products. Choose a magnetic or self-adhesive kit, depending on your desired use. Read on to learn how to... Read More »
Alright, after all that work, we're putting a finish on a nice panel like this. What we're going to do now is tear it up. So we've got a couple gouges and, try and get this so you can see it, there's a little ding right here. It's dented. It's the kind... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The thickness of our insulation is going to make a difference in the R-Value. So if we have... Read More »
Hi. I am David Belch with All Bright Restoration Services. Today Im with Expert Village to show you how to install windows. OK several reasons that you want to replace your window and that being infiltration. OK these windows all they have, they have no... Read More »
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 02:32 PM
steel or vinyl siding..Whats better? fricandfrac Building & Construction 12 03-03-2009 07:52 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 06:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 02:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 05:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
