Two Pipe Continuance Radiator Heating Systems - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 11-07-2010, 05:57 PM   #1
two pipe continuance radiator heating systems
Hello,
I am remodeling a small 10 X 10 kitchen. There were 2 radiators in the kitchen which was removed in order to install a built in ref. We first cap off the two radiator not knowing that it was a continuace flow radiator system. We than attached some PEX heating tubing to the copper tubing ends to allow the water from the furnace to fill the other radiators in the system and heat the house. We are still without heat. My question is: Is it necessary to use the copper pipe to attach the two ends in order to get some heat flowing again. Freezing!!!! Please reply
tookie45 is offline   Reply With Quote
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 12:31 PM
Installing bathroom sink - drains off slightly less than pipe diameter lazzlazz Plumbing 17 05-21-2010 05:12 PM
Pipe + Wood Spinner Woodee Building & Construction 5 03-02-2010 01:44 AM
Modifying existing pipe altadata Plumbing 3 02-11-2009 11:09 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
