Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Introductions
Old 11-11-2009, 09:04 PM   #16
Tankless water Heaters
Originally Posted by Yoyizit View Post
I'll take two!
Oh, that ends the argument. It's green so it must be good.
jerryh3 is offline   Reply With Quote
Old 11-12-2009, 12:35 PM   #17
Originally Posted by Heaterguy View Post
Ours sell for $425. They should not be vented out the chimney but direct vent like a dryer by venting it out the roof you probably will shorten the life of the heater, because of condensation leaking back into the unit. I'm glad it worked for your floor plan. We also sell smaller models that you can hook up to a propane tank and take a warm shower while camping.
The installation manual for mine said I must have five feet (minimum) of vertical double wall pipe for proper draught. Do you not call the double wall pipe that goes up through the roof a chimney? Whatever you call it the one on the water heater that we had was not sufficient and it had to be replaced, including putting a bigger hole through the roof.
The tankless unit itself cost about $425. The rest of the cost was installation (and parts -- my LP company wasn't giving away the two stage regulators ;-), and all that double wall pipe adds up. ) It took a lot of time to install, and the installation had to be by someone with a mechanical license or it voids the warranty.
pyper is offline   Reply With Quote
More On This Topic
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
Using your tankless water heater is as easy as turning on your faucet. Whether you have chosen a gas or electric water heater, using them is the same. Once the tankless water heater is properly installed, you simply turn on the hot water. Read More »
If you're living in a mobile home and facing your first winter, you may not be aware how difficult it can be to keep a mobile home warm. Taking the proper steps to winterize your mobile home cannot only help keep you warm, but keep your heating bills... Read More »
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Low hot water pressure crebive Plumbing 26 01-10-2010 12:54 PM
Electric tankless water heaters anyone? brokenhammer Plumbing 3 09-17-2009 10:20 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 10:59 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
