Snow Blower Issue, Erratic Engine - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 01-31-2011, 03:48 AM   #1
snow blower issue, erratic engine
I have a Sears Craftsman 9hp snow thrower model 536.887995. It starts up right away but stalls after several minutes. Then will restart and runs for maybe 10 min. This pattern continues. Eventually it will run for a while. I've changed gas, spark plug etc. manual says not to add engine cleaner. No reference either to changing (cleaning a fuel filter). Any ideas?
reekeyg is offline   Reply With Quote
Old 01-31-2011, 03:57 AM   #2
A Little Of Everything
Rewards Points: 1,364
Start by giving it a good carb cleaning.
DrHicks is offline   Reply With Quote
Old 01-31-2011, 04:05 AM   #3
thanks
well, I thought of that but the manual says not to add an engine cleaner (will harm engine). Are you saying it's Ok to add a carb cleaner?
Old 01-31-2011, 04:12 AM   #4
No.
Turn off the gas. Remove the bowl from the carb (there's usually just one bolt, in the center, holding it on), and clean it. I'd bet you have some crap floating around in there.
Get some aerosol carb cleaner and spray up into the carb while the bowl is off.
Be careful to note its position when you remove it. Some carb bowls are indented so the float can move freely. Also be careful removing and reinstalling the bowl gasket.
Old 01-31-2011, 04:14 AM   #5
hi
super thanks!
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Quatro/Consolidated Fan Blower issue Dale Barnes HVAC 5 11-14-2012 02:00 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 05:00 PM
Lennox G21Q issue gotzapped HVAC 2 11-25-2008 03:28 AM
replaced furnace blower now breaker issue Kurr HVAC 5 01-25-2007 10:22 PM
