Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Introductions
Old 10-27-2010, 01:59 PM   #1
Smooth Stucco Shower Walls / Marble Dust
Can some one please tell me what type of Marble dust and how much we should add as an aggragate to smooth stucco when applied inside a walk in shower wall? I read some earlier post about smooth stucco inside shower walls that suggested to add marble dust as an aggragate and this would make the stucco "inherently water proof" .. We have already applied the lath ,scratch coat and brown coat and later this week we plan on doing the final finish coat. We tiled the back wall of the shower pan and plan on smooth stucco for the side walls of the shower and arround the soaking tub. see photos attached and thanks in advance for help on this project. We plan on using Expo Stucco Shower coat and adding 1 lb of Marble dust per sack of stuccoSmooth Stucco Shower Walls / Marble Dust-img_1618.jpg
michaelmarrin is offline   Reply With Quote
Old 10-28-2010, 12:39 PM   #2
I'm haveing a hard time finding Marble Dust - however one suppier said white cement is Marble Dust? Is that true?
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Drywall or Denshield behind Shower Walls? atilla137 Plumbing 3 07-20-2008 10:11 AM
Stucco on interior cmu/fireplace andys Building & Construction 1 06-24-2007 04:02 PM
snading dust off new painted new sheetrocked walls purplezee Building & Construction 3 02-25-2007 05:59 PM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 07:17 PM
