Originally Posted by cpourfarid
. Anyways the
sound of water is ongoing for nearly 5-6 days. Could you please kindly share what you think may be going on. I appreciate your time in advance.
Sincerely, Crystal
Crystal,5 or 6 days?!?..you should have called someone the first time you heard it.Water damage can be very extensive.It sounds like your hot water heater has sprung a leak,at the very least go shut off the water and electric to the water heater to stop the leak.
This is urgent.Get it fixed right away.
Have you sourced out the leak yet? can you determine if it is indeed the WH?
