Rubber Pavers - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 06-11-2011, 02:51 PM   #1
rubber pavers
I'm new this site and excited that there are so many diyers. I want to put rubber pavers down on a 14'x7' concrete slab. Water will get up under the tiles and am concerned about freezing in the winter. Will this do damage to the concrete? This is covered but I do get run off in heavy rains. Has anyone used these? How about keeping these tiles clean, leaves and such.
becky brady is offline   Reply With Quote
Old 06-11-2011, 04:03 PM   #2
DIY staff
Rewards Points: 7,174
I never heard of anything like this---do you have a link to the product? It's O.K. to post a link.--Mike--
Old 06-11-2011, 04:43 PM   #3
Craftster
ghostlyvision's Avatar
Rewards Points: 95
Are these the kind you're talking about?
Rubber Pavers
My husband and I have been talking about tiling our concrete patio and saw these this morning while getting some retaining wall bricks, I was going to ask about them myself so glad to see the topic brought up.
ghostlyvision is offline   Reply With Quote
Old 06-12-2011, 07:56 AM   #4
Sorry location is important. I'm in south central Indiana, where it rains, snows and freezes in the winter. I've seen these pavers at our local big home improvement stores. They are 12" and 24" square. Made from recycled rubber tires, like rubber mulch. Plus they are only about an inch thick and I don't think I would have to glue them down as they appear to have gripping power, they are also molded to look like brick. I think they are a little pricey, $15+ for 24" square, but easier for me to handle. Lighter weight than stone for this 62yr old female that still thinks she can do anything. Thanks for your posts and interest. Maybe with all your input I can decide what I should do. I'm also concerned about bugs (spiders) and mold living under these tiles as this area is a small porch attached to the house. Thanks for any help and advice given.
Old 06-12-2011, 10:03 AM   #5
Energy Saver
HomeInsulation's Avatar
Hey becky brady,
Honestly, you're probably going to have mold and spiders under these pavers, but it's not a big deal.
If you wan't to remove them someday. A quick powerwashing will cure any blemishes.
You may want to Tapcon a piece of aluminum around the outer edge of your patio to "lock" the pavers into place. This will keep them from moving around on you.
Free How To Insulation Videos @ http://www.howtohomeinsulation.com
HomeInsulation is offline   Reply With Quote
Old 06-12-2011, 10:35 AM   #6
Thanks HomeInsulation. I had that thought and will do this. I will just have to keep spraying my bug killer.
Old 06-12-2011, 08:10 PM   #7
Welcome to the site !
Good luck with the patio
Old 06-12-2011, 08:52 PM   #8
Too Short? Cut it Again!
I have specified a lot of rubber paving products for clients and all have seemed delighted---even those most skeptical to start. The good products come in nice color choices and shapes and patterns ranging from brick patterns, to patio tiles and large rectangles. They are durable, easy to install, maintain and replace and adapt well to extreme climates (although you should not install them under such if possible). The nature of their material gives them resilience that is delightful to walk on and when you search you will find gallery images showing them in use around racetracks, pools and things. Because they have some flex to them, they are an excellent choice of material to put down over a concrete slab that might have surface imperfections that might crack harder materials.
One negative is that they are somewhat porous and will show construction dust and so forth so do not install them until the end of your project.
Don't waste your money on the box store rubber paving products. They are too thin just too start. I would be surprised if they were warranted at all.
Not sure what all these green credits will mean, if anything, but most brick paving products are made from recycled tires.
Old 06-13-2011, 08:02 AM   #9
Thanks scubadave for the welcome. Still not sure I want to do this. And thanks sdsester for your information. I'm somewhat of neat freak, as sit here looking at my clutter on my porch. rocking chairs, ferns, bakers rack, birdhouses. My garden hose is my best friend, I just hose everything down, which makes feel everything is squeeky clean. I know I should probably use stone, but the idea of something soft underfoot, and something easier to install is enticing. Keep the comments coming. Ive never been so undecided.
Old 06-13-2011, 01:43 PM   #10
Craftster
Rewards Points: 95
sdsester - can the rubber pavers be cut to fit (say, if you start laying them at the front of the patio and work to where it meets the house and need to trim them)? And if so, what would be best to cut them with?
Old 06-13-2011, 02:31 PM   #11
If using tile type, large or small, rubber pavers, you would not want to work from one edge to the opposing one. You should do a layout like you would for any tile floor so all the adjustments do not end up in a weird looking course, probably out of square with the house.
You can use sharp wood working tools to cut the pavers.
Old 06-13-2011, 04:36 PM   #12
Craftster
Rewards Points: 95
Okay, gotcha, I was mainly worried that cutting them might make them wear more quickly, but I guess if they are rubber through and through it shouldn't be a problem. Thanks.
Old 06-13-2011, 08:45 PM   #13
Manufacturers may have specific suggestions on cutting and installing.
Old 06-13-2011, 09:16 PM   #14
Craftster
Rewards Points: 95
Okay, will do my homework, thanks.
rubber hoses - code compliant? daixloxbmw Plumbing 10 01-07-2011 08:15 AM
Pavers over a concrete sidewalk Beckerad Flooring 3 07-20-2010 08:59 PM
What kind of glue do you use to put rubber pavers over concrete ? tim duffy Flooring 1 05-17-2010 12:42 PM
Help! Paver patio with standing water toeey1 Landscaping & Lawn Care 11 04-05-2010 06:54 PM
Rubber roof prices tgf40 Roofing/Siding 4 05-27-2008 01:02 PM
