Replacing A Door & Header On Loadbearing Wall - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 08-05-2010, 04:17 PM   #1
Question
Replacing a door & header on loadbearing wall
i am replacing a 60" sliding glass door with 72" French door in my unfinished basement. I will have to replace the header as well, since the current one is 12" too short. The wall is obviously load bearing, and i know i need to support the floor joists above, before ripping out the door and header. What i am having problems with, is trying to find where i can rent a set of house floor jacks... I haven't found anything yet and I don't want to buy a set.... does anyone have any ideas?
2ocnorb is offline   Reply With Quote
Old 08-05-2010, 06:44 PM   #2
Civil Engineer
Rewards Points: 4,568
When I did my kitchen load bearing wall removal project, which involved an 11 foot long header, I temporarily supported the ceiling joists using two sets of doubled 2x10's supported by doubled 2x4's on either end. By careful measuring and cutting, I was able to install the supports tightly, allowing me to support the ceiling joists without using any jacks at all. I placed the supports approximately 2 feet away from the wall to be removed on either side. There was no detectable movement of the ceiling, no cracking of drywall, and no problems. Regardless of how you support the ceiling joists, make sure the base supporting the jacks or studs is sufficiently strong. I placed a 2x10 on the floor under the studs spanning three basement joists.
Daniel Holzman is online now   Reply With Quote
Old 08-06-2010, 07:39 AM   #3
thanks Daniel! i may look into doing that. sounds like a great alternative to renting/purchasing house floor jacks.
Bearing wall header size gtimk4 Building & Construction 4 08-05-2010 12:34 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Replacing 50 year old Wall furnace with new one liz k HVAC 2 11-29-2009 10:22 PM
Replacing stud wall behind brick bayoudonnie Building & Construction 1 05-19-2008 10:34 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
