Replacement Windows - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 12-06-2009, 08:52 PM   #1
replacement windows
Hi everybody.
I'm new to this DIY site. I've been doing small projects around the house and I'm starting to take on bigger projects.
I'm working on replacing my windows. The Anderson 200 line. Came with the house. Looking to find replacement windows or firstly new jamb liners. I damaged them as I was trying to remove them. I'd love to hear some advice or info.
brooklynboy is offline   Reply With Quote
Old 12-10-2009, 08:00 PM   #2
have been a window specialist most of my life .most replacements are measured from side to side , and from top to bottom. most window company will take a full measurement , and then knock about a 1/4 inch off the entire window .and this is the standard practice for most companys . if the windows are really old you have to remove all of the material except the window stop itself .all the existing track will have to go . window frame will stay intact .meaning top, bottom,and side jambs . so pay particular attention to the detail of your window .as older homes will have window weights rather than tension spring side jambs ,hope this has been helpful . thanks jim
james greer is offline   Reply With Quote
Old 12-12-2009, 07:47 PM   #3
Wood Butcher
robin303's Avatar
Welcome from Tx.
robin303 is offline   Reply With Quote
Tags
anderson , replacement , windows
Comparing Replacement Windows Amycat Windows and Doors 72 05-31-2014 08:56 AM
Replacement Windows lucky8926 Building & Construction 36 10-13-2010 11:09 AM
Vinyl replacement windows - RBS Performance Plus? heavyharmonies Building & Construction 8 09-01-2010 03:48 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Replacement Windows-Storm Windows simon Remodeling 27 11-17-2007 05:18 PM
