Re-siding A House - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 03-29-2013, 04:47 PM   #1
Re-siding a house
We live in Colorado and my husband and I recently purchased a home and we are thinking about residing it. My husband wants to put composite lap siding on top of the current siding, which is a composite 'panel' siding. There is no housewrap on the home. Is housewrap necessary given that we are placing siding on top of siding?
Thank you!
klsmith
klsmith is offline   Reply With Quote
Old 03-29-2013, 07:40 PM   #2
Rewards Points: 774
Thank you!
klsmith
For me, I like to look at everything, so taking the old off always appeals a bit more to me.
cibula11 is offline   Reply With Quote
Old 03-29-2013, 08:41 PM   #3
Rewards Points: 13,750
In most cases one of the draw backs to siding over any other siding is all the window and door trim will need to be built out first.
I personaly would use the house wrap between the two sidings.
Old 03-30-2013, 02:03 AM   #4
Rewards Points: 156
It's also a good opportunity to address moisture issues if you remove the old siding. Rotten boards, poorly flashed windows and doors are not uncommon. Siding over siding just covers it up. Taking off the old siding gives you the opportunity to fix it. It is also a great opportunity to beef up your insulation. You can put an inch or two of foamboard insulation under the new siding for relatively little expense but a lot of potential gain.
strategery is offline   Reply With Quote
Insulated siding questions ddev Building & Construction 12 03-08-2012 08:44 PM
Adding a deck to a house with vinyl siding Timmer13 Building & Construction 2 04-15-2011 08:42 AM
Installing nail fin windows - house wrap and t 111 siding DirtDog Remodeling 3 03-16-2011 11:59 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
