One Man New Home Construction. - Introductions - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 06-17-2013, 10:31 AM   #16
Rewards Points: 199
Originally Posted by Firetech View Post
Also I forgot to ask, is your post on 8' center, they look like they could be. That is what I did on mine for strength and 8' lumber was cheaper and the span width allowed the use of smaller lumber.
Here's a pic of the finished foundation. The piers are 10" dia. at the top and 18" dia. at the bottom and extend 3" above grade and 20" below grade; they have a 5/8" vertical rebar with a flat plate welded to the top which is bolted to the post.
The posts are 6"x6" milled from the red heart of cedar varying from 28" to 34" tall and are spaced 6' apart; there are four rows, each row 8' apart.
The beams are 6"x8"x12' milled from southern yellow pine.
Everything is braced as shown with 2"x5" milled yellow pine; the attachment points are made with 1/2" bolts and poly nuts; 1/4" thick angle brackets with lag bolts attach the beams to the posts.
Arky
Arky217 is offline   Reply With Quote
Old 06-17-2013, 01:03 PM   #17
Rewards Points: 3,130
I can't help but notice that you are conspicuously avoiding answering my earlier questions about permits, plans, etc. I am really interested in learning where you could get away with building something like what you're doing. Costa Rica maybe?
Another question: If you're so broke, how did you afford an Airstream trailer?
The Following User Says Thank You to md2lgyk For This Useful Post:
gregzoll (06-17-2013)
Old 06-17-2013, 02:58 PM   #18
Firetech's Avatar
Originally Posted by BigJim
Just looking at that wooden extension ladder tells me you are one strong dude. Building alone is slow and takes a lot of thinking of how to do things without help. Ever try building a free standing carport alone, I have. I admire you for your efforts, in my book you did good.
The good part is if you wanted to come back and build a masonry foundation it would be doable.
Thanks BigJim,
After seeing how the other guy braced his house I thought about instead of using wood, go with either all thread 1/2" crossed as buck and brace scaffolding is done or unistrut so it would serve as rebar in a solid pour foundation and be stiff either pulling or pushing. That would give the best of both ideas.
Firetech is offline   Reply With Quote
The Following User Says Thank You to Firetech For This Useful Post:
BigJim (06-17-2013)
Old 06-17-2013, 03:22 PM   #19
Firetech's Avatar
I like how you will be able to go back and easily replace a rotten timber since they are attached above ground to the metal plates. Although they being made of cedar will last longer than even pressure tested post. I really like how you did that. I have no idea how you built a form for the concrete in the almost teardrop shape. 18" at bottom and 10" at the top. That is cool, it will give you a very big footprint. I guess the only at all decent part of how I did mine was that at least as much of what is sticking out above ground is below ground to make it rigid I hoped. Maybe it will stay standing until I can pour or block it in. In the meantime I'm installing 4x4 cross bracing.
Old 06-17-2013, 04:50 PM   #20
Rewards Points: 150
Great work.
I've seen many homes built with just a right hand. As long as it can sign the check, the home was built every time.
Squished is offline   Reply With Quote
Oh! 1st home! Closing in two weeks! 30 Pics! Firefighter3244 General DIY Discussions 29 07-02-2014 08:03 PM
Looking to paint 2500sq ft new construction home kehi66 Painting 0 06-03-2012 11:20 AM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Chilly inside new construction home katiealbano Building & Construction 2 04-13-2010 11:16 AM
insulation missing in new home construction Diyguy1223 Building & Construction 3 01-31-2008 08:51 AM
