One Man New Home Construction. - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 06-11-2013, 06:16 PM   #1
Firetech's Avatar
One man new home construction.
Hello All,
I started building my house last October out of necessity. I had always wanted to build my own house so........
Firetech is offline   Reply With Quote
Old 06-11-2013, 06:39 PM   #2
Rewards Points: 14,300
Ok so is there a question?
One person building a house Hmm.
Good luck with that one.
Old 06-11-2013, 07:26 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 904
Hey Firetech- welcome to the forum!
If you get around to it- show us some pics. of your place with a little back story. Curious how one person builds a house.
Old 06-11-2013, 07:28 PM   #4
General Contractor
CENTERLINE MV's Avatar
Very curious first post. Maybe he couldn't post pictures due to low post count?
CENTERLINE MV is offline   Reply With Quote
The Following User Says Thank You to CENTERLINE MV For This Useful Post:
Firetech (06-15-2013)
Old 06-15-2013, 10:27 PM   #5
Firetech's Avatar
It really was not hard at all, it just takes being broke and needing a place to live bigger than an airstream for me and my family.
One man new home construction.-image-1715462281.jpg   One man new home construction.-image-3506066143.jpg   One man new home construction.-image-3530940130.jpg   One man new home construction.-image-1084184112.jpg   One man new home construction.-image-2733670286.jpg
Old 06-15-2013, 10:45 PM   #6
Firetech's Avatar
First I had to build a foundation that could be on a hill affordable and done by myself. Digging foundation by hand and laying block seemed overwhelming since it might be 2 week gap in working on it. I decided that me and a post hole digger could make a post foundation out of 6x6 treated. Each hole has 12" diameter quick create forms with rebar. Also they are driven into the sandstone below. Each is at least 4ft deep. This was the only thing that I could do since a footer will fill with water and become a muddy mess. This way one pole at a time.
Old 06-16-2013, 11:16 AM   #7
Rewards Points: 3,130
Where are you located? Where did you get the plans for this house? Do you have a permit? It certainly would never be approved where I live.
I really do appreciate the amount of work involved. My wife and I, both in our 60s, spent most of the last three years building our log home almost entirely by ourselves. Subbed out the foundation just to get it done more quickly, and the HVAC because we couldn't legally work on that. We did literally everything else. Lived in our RV on the property the whole time.
Old 06-16-2013, 02:12 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 772
Just looking at that wooden extension ladder tells me you are one strong dude. Building alone is slow and takes a lot of thinking of how to do things without help. Ever try building a free standing carport alone, I have. I admire you for your efforts, in my book you did good.
The good part is if you wanted to come back and build a masonry foundation it would be doable.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 06-16-2013, 03:50 PM   #9
Rewards Points: 201
Like Firetech said, just takes determination:
Kidding aside, it can be done, even by a 67 year old.
(Including milling the lumber that it was made from)
But Firetech, I'm curious, I don't seem to see any bracing on your foundation other than some of the posts rising a bit higher than the sills.
Do you plan on adding bracing later ?
Arky
Arky217 is offline   Reply With Quote
Old 06-16-2013, 04:27 PM   #10
Old School
Willie T's Avatar
Well done!
Willie T
Old 06-16-2013, 04:30 PM   #11
Rewards Points: 6,652
Originally Posted by Firetech View Post
Hello All,
This is a new one. Usually most of us either buy one already put together, and fix it up, or rent a place. Unless you are in the wilderness, jungles, arctic, shelter is not a necessity in populated areas.
Even in those areas in the U.S. that are still considered non-populated, most people either just have a manufactured home put in place, or build a habitat so that they have some level of comfort, and a place to eat and sleep.
Old 06-16-2013, 04:32 PM   #12
Anyone as a new user on this site, can post pictures to it, by either placing a link in their post, to their flickr account, or in the post, through the Advanced button.
Only thing you cannot do as a new user, is send Private Messages.
Old 06-16-2013, 04:34 PM   #13
First off, those piers are really undersized, second the beams are going to rot out over time, even quicker if in a snow area, due to being embedded in concrete. If in a area that is rampant with wild fires, those piers should be at least six feet off the ground, same goes if you get heavy snow fall.
Old 06-16-2013, 08:42 PM   #14
Firetech's Avatar
Hello Arky217,
Thanks for the pictures of the houses. I really like the satellite dish and toilet. As far as the pole foundation goes I am going back and installing cross braceing between the 6x6 posts just as you did. Is there bracing on all of the support posts or just the perimeter ones. I really should have done this already but I was trying my best to get it dried in. I really like the vinyl siding, metal roof and front porch. It looks great.
Old 06-16-2013, 08:48 PM   #15
Firetech's Avatar
Also I forgot to ask, is your post on 8' center, they look like they could be. That is what I did on mine for strength and 8' lumber was cheaper and the span width allowed the use of smaller lumber.
Oh! 1st home! Closing in two weeks! 30 Pics! Firefighter3244 General DIY Discussions 29 07-02-2014 08:03 PM
Looking to paint 2500sq ft new construction home kehi66 Painting 0 06-03-2012 11:20 AM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Chilly inside new construction home katiealbano Building & Construction 2 04-13-2010 11:16 AM
insulation missing in new home construction Diyguy1223 Building & Construction 3 01-31-2008 08:51 AM
