Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Introductions
Old 11-10-2009, 10:40 AM   #1
old wet barn boards
my freinds i have taking down an old 1800,S DAIRY BARN and alot of the boards are wet,solid in the center but a little punky on one side of board. alot of the boards are 24 inches or better . my question is can they be dried and planed. the barn was 46 wide and 96 long .all nocthed and pegged beams. it was a nightmare to take down and i figure it will take a lifetime to refinish all the boards. its too bad all our old barns in oswego couty new york are falling down,but maybe with your help I can preserve some of it. some of my family think im nuts but go and price a 18foot by 24 inch board they are not to be had. thank you bobby battles
LINUS is offline   Reply With Quote
Old 11-10-2009, 06:19 PM   #2
old wet barn boards
You have got yourself a wonderful stash.
I've made some really fine clocks and trunks out of old barn wood.
Yes they can be planed. yes it will dry out-they are wet with water,not sap--drying will be quick.
Minwax Wipe on Poly will bring out the amazing colors and help harden the soft wood fibers.
You may find that a belt sander(used outside) is all you need to grind off the weathered outside of the boards.
Play around and experiment. Post some pictures after you sand and oil up a sample.--MIKE--
Old 11-10-2009, 07:43 PM   #3
old wet barn boards
Get them under cover and stack them with stickers between to dry them out. You should have some good material to work with.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 11-10-2009, 10:38 PM   #4
old wet barn boards
I'm jealous! Looking forward to hearing about and seeing photos of your progress.
justgreenhomes is offline   Reply With Quote
Old 11-11-2009, 07:08 AM   #5
old wet barn boards
I'm jealous to. I got a funny back handed compliment on a clock I made out of old barn wood.
I was standing in line at the clock shop,holding the newly completed project,when an older gal ahead of me turned and said,"Young man,no matter what it costs you should repair the original movement in that clock.
You know it devalues an antique to put in a new movement!"
That made my day.----MIKE----
More On This Topic
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
Harvesting tobacco is a complicated and exact science. Your schedule for harvesting tobacco leaves depends on various factors, including the variety and type of the tobacco, the age of the leaf, the contents of the water at harvest and the position of... Read More »
Hi my name is Tim Labelle this is my wife April were the owners of Pet Barn Exotics in Hartland, Michigan were here on behalf of Expert Village we hope you choose the right pet. In this segment we will be discussin going on vacation. For those of you who... Read More »
But you want to be careful and make sure that you don't case the leather to much. That you don't put to much moisture on it because what can happen then is the leather can get really mushy and even though it might take it take an impression it might not... Read More »
Barn doors experience a lot of wear and tear. When it's time to replace them, you either can build new doors yourself or purchase ready-made. Each door mounting kit is slightly different, so be sure to read the directions before proceeding. Read More »
help with major plumbing work in barn schmolze Plumbing 1 02-02-2009 09:58 PM
NEWBIE- Looking to build my own Barn Home in Idaho LAWFISH General Discussion 2 11-14-2008 08:43 PM
I've lost power at my barn Jim Owens Electrical 11 10-11-2008 11:58 PM
hardwood flooring boards matjone Flooring 4 02-01-2008 06:35 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
