Not Sure What To Do With Old Planked Subfloor? - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 07-23-2008, 03:28 PM   #1
Not sure what to do with old planked subfloor?
I'm renovating a 1910 farmhouse and would like to tile the kitchen. The original flooring consisted of ship lapped 2x8 fir planks on the joists with finished 2x4 T&G fir flooring on top. At some point in the last 100 years someone layed orange resilient tiles over the fir flooring and then (presumabley) years later nailed down 3/8" OSB over it all and layed lino on that. Sheesh! I want to install tile in the kitchen and refinish the original flooring in the rest of the house. This weekend I'm hoping to strip everything down to the fir T&G, and then carefully pull it out and salvage it.
My question is: should I then pull out the planks underneath the flooring and start fresh, gluing and nailing T&G subfloor to the floor joists? Or should I just glue and nail subfloor over the original planks? I wouldn't mind salvaging the planks, they look to be mostly clear and would provide some nice material to rebuild the stair treads and window stools. Material like that just doesn't exist anymore. It would also mean though that I would probably have to double up the 3/4" subfloor to get the tile to the same height as the original flooring in the dining room, and cutting the planks out around the existing walls and such will be a serious pain in the butt.
Any suggestions?
whiskeykid is offline   Reply With Quote
Old 07-23-2008, 03:52 PM   #2
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
I would pull the sub floor. Like you said they don't make wood like that anymore. You don't have to cut it exactly flush with the existing walls. Your first layer of OSB should be as close to the original thickness of the sub floor. Your 2nd layer will go up flush to the wall. That is how I would do it but I'm no expert.
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
Replacing my subfloor DanBress Flooring 17 02-16-2008 09:11 AM
Replace subfloor? BigJimmy Building & Construction 2 01-13-2008 02:18 PM
BAthroom Subfloor Blaze25 Flooring 3 11-17-2006 09:06 AM
