Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Introductions
Old 02-23-2013, 10:38 PM   #16
New member from Iowa!
By the way, do you have electric heat, or hot water? AC? Is it a modular home?
cleveman is offline   Reply With Quote
Old 02-23-2013, 10:44 PM   #17
Send a message via AIM to Zach5.9CTD Send a message via MSN to Zach5.9CTD Send a message via Yahoo to Zach5.9CTD Send a message via Skype™ to Zach5.9CTD
ohhh i gotcha.....i thought you were talking something INSIDE the actual soffit...id have to look and see what they are.
As far as heat goes, he has hot water baseboard heaters as well as a normal furnace with ducting. The furnace and ducting he said is mainly used to run the central AC in the summer. not sure if it has heating capabilities or not.
Yes pre-fab/modular home.
Zach5.9CTD is offline   Reply With Quote
Old 02-24-2013, 10:31 AM   #18
Sounds like a nice heating set-up. If you have a furnace, you can use it when you have a cold snap in the fall or spring, and just get the boiler running when the cold weather is here to stay.
Old 02-24-2013, 11:22 AM   #19
yeah, the guy is a licensed plumber and seems like he knew what he was doing to help minimize costs etc.
Best way to repair rotted structural wood member? miamicuse Carpentry 20 11-19-2011 05:30 PM
Proper fix for floor joist simp82 Building & Construction 6 02-20-2011 01:29 PM
New Member 25thmustang Introductions 2 09-01-2010 08:21 PM
