Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Introductions
Old 10-21-2012, 11:21 PM   #1
New Member
Hi,
Just joined today because my youngest daughter just bout a townhouse in Columbia, MD and I was doing some repair work and ran into a problem with a broken toilet floor flange. I thought I had seen repair kits for those on one of the DIY shows on TV so off to Home Depot and sure enough I got the small one that is supposed to slip under the flange. Problem was that the previous owner had tiled the floor and the top of the flange was flush with the surface. Also the screws were not coming out either. Solved the problem by placing the metal part on top of the flange and screwing it down with two large stainless sheet metal screws. The other problem with those is that it does not provide a way for keeping the bolts from turning so I ran a nut down against the plate and another problem solved.
I am sure there will be more challenges in the upcoming weeks and hope to use the forum as necessary.
goldpanner in PA
goldpanner is offline   Reply With Quote
Old 10-22-2012, 12:51 PM   #2
New Member
Good luck ,and stay strong its a long and at moments stressful but the pay off is great.Im doing renovation my self as well.
ManuelR is offline   Reply With Quote
Old 10-22-2012, 10:46 PM   #3
Tool Geek
PaliBob's Avatar
New Member
That was a good solution.Welcome to the Forum
It is a good idea to include your location in your profile.
Also check out how to Post pictures in the How To section,
To add your location to your profile see more How-To
& Stay Safe
.....Bob Lavery
Old 10-24-2012, 12:33 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
New Member
Howdy.
- Build Well -
Best way to repair rotted structural wood member? miamicuse Carpentry 20 11-19-2011 05:30 PM
Proper fix for floor joist simp82 Building & Construction 6 02-20-2011 01:29 PM
Hello, new member from Minnesota xorion Introductions 1 07-22-2009 07:33 PM
Contractors Talk - Anyone a member Rivethead General Discussion 4 01-29-2009 07:20 AM
