Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Introductions
Old 12-15-2011, 12:49 AM   #1
New house purchase
Hey all, I am currently in the process of buying a foreclosed home. There are many things I need/want to a do once I close. Looking forward to gaining some knowledge here.
Krauty is offline   Reply With Quote
Old 12-15-2011, 06:11 AM   #2
Learning Things Every Day
Jay 78's Avatar
New house purchase
Welcome!
I hear that foreclosed houses are rarely "move-in ready", so you probably have your work cut out for you.
There's lots of great info here. The search box is your friend!
Under Construction
Jay 78 is offline   Reply With Quote
Old 12-15-2011, 12:45 PM   #3
biggles's Avatar
New house purchase
visit it in the pouring rain roof check and in the cold heat check unless the water is "drained down" if not and the heat is off inquirer so what about the water in the pipes...
Old 12-15-2011, 01:24 PM   #4
New house purchase
I looked at a few foreclosed houses, but there are too many issues for my tastes -- especially the fact that most of them had past due utility bills that needed to be paid before the utilities could be turned on for an inspection.
Good luck! I hope everything works out well for you.
pyper is offline   Reply With Quote
Old 12-15-2011, 04:23 PM   #5
New house purchase
This house is actually pretty much move in ready. It was built in 2006, so it's fairly new. The heat and water are both on so I was lucky enough to test those out. I currently need all appliances, sump pump, water softener....and some major cleaning! Long list of things to do outside once spring rolls around. Thanks for the reply's!
Old 12-23-2011, 12:13 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
New house purchase
Congratulations and Welcome to the site.
- Build Well -
Old 12-23-2011, 11:12 PM   #7
New house purchase
Welcome.
You want to assume in northern climates that the plumbing will have frozen. Water heater will need to be replaced. Flooding damage may have rendered the furnace useless and caused mold damage throughout the basement.
The sewer line out to the street is a major expense. Other than that, you should be able to see what you are dealing with. As with any home, you have to become "acquainted". Maybe the basement floods when it rains, etc. A termite inspection is of no use to you. It just means that some guy shined a light around and didn't see any termites at the time when he shone the light. It is no guarantee that the place isn't infested with termites, so you will want to determine that first.
cleveman is offline   Reply With Quote
Old 12-24-2011, 05:26 AM   #8
New house purchase
i am new to the forum too. good luck
patriox is offline   Reply With Quote
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Mast and weatherhead pulled from house, conflicting information from POCO subcontract SleepnZJ Electrical 1 11-02-2011 10:39 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
