Mobile Home Light Switch - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 03-26-2009, 09:12 AM   #1
Lightbulb
I need help. My mobile home light switch is not working. It is one of those that you touch and the lever goes up and down. Not the off and on switch. The switch has not screws. We popped off the lever and it has a rectangle and what looks like a power surge red button. How do we get to the wires to replace this?
Thoward002 is offline   Reply With Quote
Old 03-26-2009, 01:02 PM   #2
Mobile home stuff can be really weird sometimes.
First, find the breaker that supplies power to that switch, move the breaker to off, and put tape over the breaker.
Next, since it has no screws, i'd use a flat tip screwdriver, and very carefully, see if the switch plate will pry out. Another idea would be to take a digital picture of the switch, and armed with that, go to your local hardware store, and talk to an associate in the electrical section. If you can find a switch that's identical, you can look at how it's put together and "reverse engineer" how it must be removed.
Best of luck...Like I said, mobile home stuff often isn't what people consider "standard" and can be put together very odd.
ltmayhem is offline   Reply With Quote
Installing New Light Switch (NOT REPLACING AN EXSISTING ONE) Light Out on Hillsboro Be Electrical 10 03-11-2012 08:27 PM
question moving light switch niemie13 Electrical 4 01-09-2009 02:12 PM
Fan resets after light switch is toggled texashomeowner123 Electrical 7 12-21-2008 05:00 PM
Dual Dimmer Switch Headache! BrumGuy Electrical 3 12-02-2008 02:39 PM
4-way switch and light fixture rtyui2 Electrical 3 12-23-2007 09:48 PM
