Log Cabin Roof Venting - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 04-19-2013, 11:25 AM   #1
Log cabin roof venting
I have a log cabin with cathedral type ceilings. The only vents that I can see are in the soffit. None in the roof or gable. What would be the best to get the hot air out, roof venting or gable?
ronnieb is offline   Reply With Quote
Old 04-19-2013, 12:15 PM   #2
Rewards Points: 13,300
Need to find out what type and how much insulation is in the ceiling.
If they jamed it full of fiberglass insulation and there's no air space then vents will do you no good.
If it's foam then no vents may be needed.
Old 04-19-2013, 12:35 PM   #3
Venting
Thanks, but I am speaking of a cathedral ceiling with exposed joists, then the roof decking. Are you speaking of between the roof decking and the roof?
Old 04-19-2013, 02:31 PM   #4
If there's just 1-1/2 T X G used for sheathing then the shingles, what are you expecting to vent?
Short of an opening sky light I see no way to vent it.
Got a picture?
Old 04-21-2013, 04:46 AM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Hi Ron, Welcome to the Forum
It is a good idea to include your location in your profile.
Also check out how to Post pictures in the How To section.
How to add your location: Go-To
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-21-2013, 05:51 PM   #6
www.inspectorzo.com
Send a message via Skype™ to InspectorZo
Talking
Roof venting will probably work the best. Allows the hot air to exit at the highest elevetions. If a mechanical means is not a consideration for you, consider a roof whirlybird turbine ventilator type fan. If mechanical means is an option for you, consider a thermostatically controlled powered ventilator such as the Maestro Power Vent.
Hope this helps.
Humbly submitted,
InspectorZo
InspectorZo is offline   Reply With Quote
venting my roof properly MLMIB Roofing/Siding 2 08-12-2010 08:14 AM
Roof Venting??? JoAnn Roofing/Siding 2 03-17-2010 10:42 AM
Proper venting of new roof on attached garage jlatulippe Roofing/Siding 1 11-26-2009 04:24 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Roof Venting Issue, crawlspace supton Roofing/Siding 1 11-12-2008 07:44 AM
