Lighting Outage In Basement - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 08-08-2013, 11:05 AM   #1
Lighting Outage in basement
I'm running out of ideas on how to fix the following problem. All ideas appreciated.
I have a 2 3-way light switches (one at the top of the stairs to my basement and one at the bottom). Both control 2 lights. One day they randomly both went out. I checked both bulbs and both are fine and also checked the switches going different ways to make sure it wasn't a switch problem. Next, I reset all GFCI outlets on the first floor and in the basement and still nothing. I've also turned the breakers off and back on and still nothing. Finally, I purchased a voltage tester and it appears that no voltage is going to the light switch in the basement, but the switch at the top of the starway is getting voltage. It appears the basement switch is the lead switch. I've turned this switch up and down and in each scenario, there is no voltage coming to the switch.
Any ideas or fixes?
saugolfer1 is offline   Reply With Quote
Old 08-08-2013, 11:16 AM   #2
I'd replace the switch at the bottom of the stairs
RoyalAcresRod is offline   Reply With Quote
Recessed lighting in basement - thoughts on layout sheffdave2002 Remodeling 15 11-20-2012 09:49 PM
Installing basement recessed lighting jdtox Electrical 13 05-06-2012 09:44 AM
Lighting in Basement nhoj Electrical 14 02-25-2012 03:51 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
