Leaking Shower In Mobile Home - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 12-11-2009, 06:19 AM   #1
Send a message via Skype™ to disna
Leaking shower in mobile home
Hi from France,
I bought a 20 year old mobile home last month. It looks quite nice inside but I'm not sure about its durability (did I get that word right?). The shower tray is leaking from underneath and even my bedroom (which is next to the bathroom) gets flooded each time we take a shower.
Is there anyone who might have had the same kind of problem who could help me?
Thanks in advance.
Merry Christmas to everyone!!
disna is offline   Reply With Quote
Old 12-11-2009, 07:48 AM   #2
ccarlisle's Avatar
Salut du Québec! De quelle région etes-vous...ah-ha, il semble qu'il me manque certains accents sur mon clavier - ou je ne les trouve pas - mais je persiste quand-meme...peut-etre meme en anglais pour ceux qui ont la meme question.
You have no choice but to demolish the shower to locate the leak exactly; but if it is coming from the shower pan (the base you stand on) then these can be easily replaced with new plastic bases. Could be the drain, or the caulkiing around the drain assembly. Either way, you will have to remove it only to find out. New bases around here are about US$400.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 12-11-2009, 08:14 AM   #3
Salut CCarlisle,
Merci bien pour ta réponse qui est pleine de bon sens, aah j'aurai dû y penser mais je ne suis q'une femme sans expérience dans le brico.
Au fait, je suis de la région Lyonnaise, de Mornant très exactement.
Yes new bases are quite cheap over here too. In fact I saw a full shower unit complete with those spa things and the glass doors and base for 200 Euros.
But as I have only just bought the house I shall have to wait for some time before I could buy anything as I have spent all the money I've been saving.
Old 12-11-2009, 08:25 AM   #4
ccarlisle's Avatar
Salut!...j'ai passé plusieurs années dans le canton de Vaud en Suisse - ca fait quand-meme un bon moment - Vevey, au bord du lac Léman vis-a-vis des alpes francaises. Je cherche toujours les accents qu'il me faut et ca prend deux fois plus longtemps de répondre...hmmm
You may need a plumber or a good handyman to do the job - but itès about a day's worth. You don't want a mould problem on top of everything else.
Old 12-11-2009, 08:46 AM   #5
Oui, c'est une très belle région. Je suis pas loin des Alpes et le paysage est magnifique. Avant j'habitais la Côte d'Azur. Ca change beaucoup.
Les accents sont à droite du clavier normalement.
Old 12-12-2009, 07:42 PM   #6
Wood Butcher
robin303's Avatar
Welcome from TX. What is bad about mobile homes is back then they used particle board which swells up bad.
robin303 is offline   Reply With Quote
Tub leaking past shower curtain Outbacker Plumbing 8 12-10-2010 04:15 PM
Shower Faucet Leaking NightOfDiscovery Plumbing 2 08-17-2009 10:58 PM
leaking 7 yr old shower blitzndyna Remodeling 3 05-18-2008 08:15 PM
Mobile home electric. RobertS Electrical 7 02-27-2008 12:25 PM
