Intro From Beacon NY - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 08-22-2011, 01:50 PM   #1
thepodger's Avatar
Intro from Beacon NY
Hello All,
Just moved into a old wood frame house this past January. (I would not recommend winter moves unless you MUST.) So far I have installed 6 new ceilings to cover over the cracked and deteriorating plaster ones. Because of this experience I feel the sheetrock jack is an invention that should be mentioned in the conversation as sliced bread. I have plenty of insulation work to do and some electrical. I will definitely be hitting up the forums for advice on spray foam as the winter heating bill was not cheap.
I am a network sysadmin, so I will also be networking the house with ethernet too. Thank you for providing a forum to share know-how. It is a great resource for the DIY-er.
thepodger is offline   Reply With Quote
Old 08-25-2011, 03:47 AM   #2
m1951mm's Avatar
I have to agree with you, this site has so much knowledge behind it!!!! I sure hope that you will be able to get some of that insulation done prior to the LONG COLD winter and with the help from the contributors lots of your questions will be answered here.
Good Luck and Welcome.
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
Intro to Cheeto Cheeto Introductions 1 12-11-2010 09:57 AM
Intro PTP WX Introductions 0 11-04-2009 09:30 PM
My intro Lazy_Jake Introductions 2 10-31-2009 03:17 PM
intro ccc Introductions 1 10-28-2009 03:07 AM
Intro raam Introductions 3 02-12-2008 11:00 AM
