Howdy All, 1st Home At 50 ?!? - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 09-25-2012, 08:41 AM   #1
OregonThe Shower me state
Turbogus's Avatar
Howdy all, 1st home at 50 ?!?
Hello everyone,
Well finally got my ducks all in a row and recently learned that I was eligible for Fed VA loan so after all these years took the plunge at long last and bought (buying) our first home. It was built in '68, not an auspicious year I know and had some renovations since. Found some artifacts in the garage loft that I recognized to be from the '70's namely a wading pool with a distinctive '70's pattern and an old pair of Goodyear Polyglass tires, both under the thickest layer of dust I've ever seen. Took a couple of hours with my shop vac before I started stowing our stuff up there.
Finding a few problems undiscovered during the home inspection (in which I took part) and the disclosure process. Nothing that can't be handled, just will take knowledge/time/money.
Sure am glad to find this Vbulletin forum. I belong to others and am used to the format. Thanks to Nathan for the welcome aboard.
Turbogus is offline   Reply With Quote
Old 09-25-2012, 09:08 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Congratulations and welcome.
- Build Well -
Old 09-25-2012, 09:11 AM   #3
Rewards Points: 14,312
Welcome
Pretty exciting and can be overwelming when getting your first home.
If I may make a few suggestions I'd give to any first timer.
Start on the outside before cold weather sets in to make sure your home is water tight and sealed.
Start at the top and work your way down inspecting it. Check all the vent seals on the roof jacks, check condition of any flashings, if there rusted or there roofing tar all over then replace them or get someone to replace them. That a sure sign they have been leaking.
Check all the siding for rot, damage, peeling paint and fix it.
Air seal the whole house, which just means spraying some expanding foam in any holes where wiring, plumbing were run through the floors or top and bottom plates and around any ceiling lights or fan where installed.
Do a Google search on "insulation zone map" to check to see how much insulation should be in your attic. Add more if needed.
Concider installing replacement windows if you have old wooden windows.
Make sure you have both unblocked soffit vents and a ridge vent on the roof.
Now you can work on the fofo stuff inside.
The reasons I made these suggestions is, everyone of them will help prevent damage to the inside of the house, and there going to save you money in the long run not cost you.
When working inside until your up to speed on how to do repairs and start to get all the tools your going to need stick with one room at a time and stay away from the bathroom and kitchen for a while until you have lived in the home long enough to see what does and does not work for flow and layout of the area.
PaliBob (09-25-2012)
Old 09-25-2012, 11:56 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Hi Turbo Welcome to the Forum
Helps to post pics, check out how to Post pictures in the How To section.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-25-2012, 03:59 PM   #5
Turbogus's Avatar
Thanks for the welcomes all,
Here's a front shot of the place;
She's got a new roof (2nd) new Hardee siding, new vinyl windows, recent gutters and at least 20 inches of insulation in the attic. I followed the home inspector all around including the attic and crawl space. One concern that's cropped up since is sediment in the hot water and an under slab gas line beneath the original back porch (now a spare room) no permits found and it's reckoned that the addition (on the slab) was done in the late '70's. I have more posted on these issues on other sections of this forum.
We did go so far as to swap out the old Tappan drop in oven for a more modern Kitchen Aid flat top freestanding oven we got from Hab 4 Hum for only $80 clams.
Old 09-25-2012, 05:29 PM   #6
Rewards Points: 264
Welcome to the forum and congrats on the new home.
Awoodfloorguy is offline   Reply With Quote
The Following User Says Thank You to Awoodfloorguy For This Useful Post:
Turbogus (09-26-2012)
1938 TN Home - My First Home, My First project, Tons of Pictures!!! Firefighter3244 Project Showcase 78 07-01-2014 10:55 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 09:34 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
