How To Install Handrail On Drywall - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 03-07-2013, 04:01 PM   #1
how to install handrail on drywall
Hi...newbie here. I want to put a handrail on the stairs to the basement. I have the brackets & thought I would just have to find the studs so it would be sturdy enough. Lo and behold...no studs so have to attach the bracket to drywall. Do I use those big spiral plastic plugs & how do I put the plugs in? Do I drill a small hole or one hole that is just a bit smaller than the plug and then tap the plug into the hole? I'm a female and not young so go easy on me will ya? Thanks a bunch.
cdryan21 is offline   Reply With Quote
Old 03-07-2013, 04:17 PM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
There has to be a stud somewhere in the wall. Are you putting up a long handrail (full length of stairs) or just a partial (half the stairs are open/etc)?
Attaching the handrail to drywall using plastic anchors is only going to get someone hurt. They will eventually fail, probably when someone leans on the rail when they really need to use it. If you really cannot find the studs and MUST fasten to the drywall, toggle bolts are the better option, though I still wouldn't want to do that way.
Borrow a studfinder from a neighbor, or buy one - they aren't that expensive: $10 to $20 for a homeowner grade unit. That will help you to locate the studs.
hyunelan2 is offline   Reply With Quote
Old 03-07-2013, 04:24 PM   #3
how to install handrailo drywall
I'm installing a 12 ft. railing. There is open faced drywall going down the stairs with open storage shelves on the other side. I get what you mean by it being unstable though. Heck, the house is up for sale & the inspector will pick up on this in second. I have a stud finder, never used - maybe there is a stud at the top of the stair as there is one at the bottom. Myself I've fallen three times down those stairs !!
How would you install drywall to ceiling??? oodssoo Drywall & Plaster 8 12-01-2012 04:50 PM
Cement board over drywall during vinyl shower pan install asc12 Tiling, ceramics, marble 6 02-25-2012 08:19 AM
install ceiling box for fan while drywall is off collegetry Electrical 30 02-12-2012 10:17 AM
What Thickness Drywall To Install Over Acoustic Ceiling? dsq Drywall & Plaster 12 02-08-2009 08:27 AM
