Home Wiring...some Plugs Stopped Working, Others Are Fine. - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 12-14-2011, 03:48 PM   #1
Home wiring...some plugs stopped working, others are fine.
My stepson tried to turn on the Christmas lights, said they went pop. Now the one outside plug doesn't work as well as the 2 in the master bathroom on the opposite side of the house. Can anyone help me, I dont know what is wrong?
crazyordeal is offline   Reply With Quote
Old 12-14-2011, 04:00 PM   #2
Sounds like you either tripped a breaker or a GFCI protecting part of that circuit. Start by checking the bathroom and see if either outlet is GFCI receptacle that needs to be reset. If that doesn't work, check your breakers and see if any of them tripped (keep in mind that a tripped breaker will not spring all the way to the "off" position; you will probably need to switch the breaker off and then back on).
clashley is offline   Reply With Quote
Old 12-14-2011, 04:12 PM   #3
I actually did true all of those suggestions, no grci in the bathroom, and just to make sure I reset every one in the house I found, as well as flipping the breakers several times
Light switches stopped working HALLJ12 Electrical 2 11-06-2011 02:50 AM
Trane Outside fan stopped working - cap or relay? JAWyrick HVAC 2 07-12-2011 11:03 AM
outlets in garage and exterior outlet stopped working littleturley99 Electrical 16 07-10-2011 10:08 PM
2 lights stopped working! ohwinnipeg Electrical 13 01-12-2010 10:18 PM
Halogen motion sensor light stopped working, Incandescent still works keyser soze Electrical 6 05-29-2007 08:53 PM
