Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Introductions
Old 11-02-2009, 10:38 PM   #1
Default Hi y'all
Hi y'all,
I wish I had found out about this place a long time ago. We've been renovating our house one room at a time. We did the bathroom first, about 8 years ago. Then we added on 400SF for a new kitchen. Then we took two bedrooms down to the studs to create a master BR and dressing room. We lived with that a couple years and then took the space where the old kitchen had been away (that is, past the studs) and rebuilt that into a music studio.
We used various contractors to do that work, to varying degrees. Now that I've found this place we're on our last room. I'm doing most of the work. We tore it down to the studs and I re-framed new studs inside the old, squaring and plumbing everything. We've got the electric & insulation in, and the drywall guys have two layers of mud up. Not too much longer.
pyper is offline   Reply With Quote
Old 11-03-2009, 01:07 AM   #2
Default Good Luck Pyper
I just found this place too. I'm hoping it comes in handy. I just bought a 1270 sf piece O crap. Plan is a total redo plus another 1650 sf up.
Are you doing the work yourself because your sick of paying contractors or you've seen enoughe to do yourself now?
tdubs is offline   Reply With Quote
Old 11-03-2009, 02:02 PM   #3
Are you doing the work yourself because your sick of paying contractors or you've seen enough to do yourself now?
I'm actually working with a contractor. That is, he comes over and helps from time to time, but he mainly only wants to work if I'm there working too. He must be the only contractor in the country who wants the homeowner involved.
In part it's because of the cost -- the hourly cost-to-me of the guys swinging the hammers (don't know how much of that they take home) is generally higher than my hourly take-home.
In part it's because renovation is tedious to do a good job at. I'm willing to cut each piece to fit and to check to make sure everything is plumb, square, and in the same plane, but the contractors we've worked with in the past pretty much weren't. So even if you're willing to pay, it's not always possible to get the work done the way you want it.
And I have all the tools and know how to use them. Having a licensed contractor available to bounce ideas off of is a great plus.
More On This Topic
So this is where we are going to put the new outlet. I have a stud running down along here or you can find your studs with a stud finder. In an older house a lot of times you can see the nail line running down the wall where they nailed the sheet-rock to... Read More »
The drywall you choose for your next home improvement project depends upon the room in which you are planning to work. Drywall, often referred to as wallboard, is available in different varieties, lengths and widths. Here's how to choose drywall for your... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and an insulation inspection on this home. You want to think of knee walls being secured correctly. You can see this house with the... Read More »
Hi, I'm Ann Kennedy and on behalf of Expert Village, I'm here to talk to you about understanding the nature of reading. Every room is a reading room. Reading does not happen in isolation. You can go into anyone's home where there is children and you'll... Read More »
We're back in our room and now we've got, mostly finished, drywall and a coat of primer paint and we chose this orange primer color because we're going to come over it with a caramel color. Drywall, mud, tape, sanding and a coat of primer always over... Read More »
Howdy y'all from the country of TEXAS TuscolaMatt Introductions 0 11-20-2008 02:34 PM
hi ya'll Jimmy417 Introductions 1 09-17-2008 02:02 AM
Hey Y'all boatguy1965 Introductions 1 06-11-2008 07:25 AM
Howdy y'all CarpenterJim Introductions 14 03-02-2008 11:41 PM
A quick hi y'all andybuildz Introductions 2 11-20-2007 12:11 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
