Help Mrs. Santa Install A Frame For Drop In Whirlpool. - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 07-29-2010, 10:54 AM   #1
Help Mrs. Santa install a frame for drop in whirlpool.
I found a great buy on a used whirlpool bath tub. It is 41" X 72'. My new tub room is 9'X9'. The water lines are on a wall across the room in the closet. No problem with electrical outlets(one on each wall). How do I build a frame? What tools will I need? What do you make the frame out of? The motor is on the left side with the facets at the top end. Does the tub rest on the frame? The tub is in another town and I only looked at it once. It appeared to be in A-1 shape underneath. It was taken out because they no longer needed it for a handicapped child and it took up so much room. I am disabled and need it for health reasons. My husband is handy with woodworking and I think he can do this, if he knows what we need and what to do first. Thanks from Arkansas
mssanta is offline   Reply With Quote
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Door frame reinforcement? AppleMac*Fit Building & Construction 6 02-01-2010 06:48 PM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 04:35 PM
How to install Replacement window in 2x4 frame? BFD8 Remodeling 18 01-07-2009 12:56 PM
Install whirlpool wilddngy Plumbing 1 06-07-2006 07:22 PM
