Hello From Nova Scotia, Canada - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 02-17-2013, 01:11 PM   #1
Hello from Nova Scotia, Canada
Hi all,
By way of introduction, I am a home owner, considered by some to be somewhat handy, and always looking to find new ways to solve common problems that we have been living with for years.
For example, my first posting is on suggestions about how to hook up an electric dryer in a very tight area when the vent hole on the back of the dryer doesn't line up with the pipe going out the wall, especially when you want to use rigid aluminium ducting and avoid using hazardous flexible ducting. Seems like a common problem that should have been solved many years ago with standard heights for vent holes in walls and standards for dryer manufacturers so they line up! Naive... I know. But we do have standards for other things that can cause injury if not done right!
I'd also like to install a sink unit between my washer and dryer, but it's only 24", so won't take a usual sink cabinet. Some laundry units include a cabinet and a sink that overlaps the cabinet so you don't need a counter top on the unit, but just try to get that sort of sink for a cabinet you want to buy that matches the rest of the cupboards.
I'll put this into another topic since this is only for introductions.
mfrenette is offline   Reply With Quote
Old 02-18-2013, 09:42 PM   #2
Registered User
Rewards Points: 5,460
Welcome, hope we can help!
Gary
Hello from Nova Scotia, Canada themilkguy Introductions 5 01-09-2013 07:28 AM
Overhead wiring to Garage (Nova Scotia) renniks Electrical 2 07-12-2012 10:20 PM
Hi from Halifax, Nova Scotia! demetrios Introductions 0 12-05-2010 12:54 PM
Expanding foam insulation, where to find it in Nova Scotia? tankd0g Building & Construction 6 06-28-2010 04:33 PM
Hello from Nova Scotia Serge R Introductions 2 12-26-2009 08:54 AM
