-   Introductions (http://www.diychatroom.com/f38/)
-   -   Hello and need Help with water and steel siding problem (http://www.diychatroom.com/f38/hello-need-help-water-steel-siding-problem-9881/)
stevarino52 07-14-2007 03:32 AM
Hello, After all of the rain that we have had, I am starting to get rain onto the concrete floor of my sunroom thru the wall plate and the concrete floor where it joins. My problem is that I have Alcoa steel siding and want to know how this can be repaired since the siding is installed at the bottom first and then finished upword. At least 8 inches of siding would have to be removed and then repaired somehow after the leaking area was fixed. Any suggestions would be greatly appreciated since we were under a drought for 2 years and now the rain does not want to stop. Just tired of cleaning up wet stagnent and mold starting water inside my sunroom. Thanks again and like I said any help will be greatly appreciated.
Steve from North Central Texas.
redline 07-14-2007 06:08 PM
How close is the ground to the bottom plate?
stevarino52 07-15-2007 02:35 AM
owner of page
Need to get ground away and also add gutters, and possibly a french drain. thank you
AtlanticWBConst. 07-15-2007 07:35 AM
That sounds about right....
stevarino52 07-15-2007 09:57 AM
owner of page
Thank You for the reply.
