#1 |
hello folks!
This is Halley Smith..
I am a newbie in this site.. |
#2 |
Tool Geek
hello folks!
Hi Halley, Welcome to the Forum
Thanks for including your location in your profile. Also check out how to Post pictures in the How To section.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. & Stay Safe .....Bob Lavery |
#3 |
Super Moderator
hello folks!
Welcome---please read posting rules----
New members: Adding your location to your profile helps in many ways.--M-- |
#4 |
hello folks!
I am new to this site and i have a question.I am installing an Exterior Steel Door But my walls are 8" thick Do i Fit the door flush to the outside .Then build the inside up or do i fit it to the inside and build the out sideup
hpap
#5 |
Super Moderator
hello folks!
Hpap----Please start a separate thread in 'windows and doors'----few members look into the ;introductions'
If the door swings into the room----it should be mounted to the inside wall----and built out on the outside. if you don't do that the door can not be fully opened. Most times a special order door is used so that there is a larger threshold ---you must get the water away from the opening----and an 8" threshold will do that.
#6 |
Lic. Builder/GC/Remodeler
hello folks!
Greetings.
- Build Well - |
| Display Modes | |
| Hi folks | mike oleary | Introductions | 2 | 01-14-2012 06:28 PM |
| Hello folks | angusW | Introductions | 2 | 12-06-2011 12:11 AM |
| The folks at this site | MikeKy55 | Off Topic | 5 | 01-30-2011 07:16 PM |
| Need help folks! Gotta find??? Please help! | MrShadetree0222 | HVAC | 1 | 10-08-2008 01:52 PM |
| Hello, and good evening folks! | MrShadetree0222 | Introductions | 2 | 10-04-2008 10:26 AM |
