-   Introductions (http://www.diychatroom.com/f38/)
-   -   hello folks! (http://www.diychatroom.com/f38/hello-folks-163037/)
HalleySmith 11-12-2012 04:34 AM
hello folks!
This is Halley Smith..
I am a newbie in this site..
PaliBob 11-12-2012 04:40 AM
Hi Halley, Welcome to the Forum
Thanks for including your location in your profile.
Also check out how to Post pictures in the How To section.
oh'mike 11-12-2012 04:44 AM
Welcome---please read posting rules----
hpap 11-12-2012 05:12 AM
Installing exterior door
I am new to this site and i have a question.I am installing an Exterior Steel Door But my walls are 8" thick Do i Fit the door flush to the outside .Then build the inside up or do i fit it to the inside and build the out sideup
hpap:)
oh'mike 11-12-2012 05:19 AM
Hpap----Please start a separate thread in 'windows and doors'----few members look into the ;introductions'
If the door swings into the room----it should be mounted to the inside wall----and built out on the outside.
if you don't do that the door can not be fully opened.
Most times a special order door is used so that there is a larger threshold ---you must get the water away from the opening----and an 8" threshold will do that.
AtlanticWBConst. 11-13-2012 12:04 PM
Greetings.
