Furnace Not Heating Bedrooms. Bleed Pipes? - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 11-30-2010, 04:47 PM   #1
Furnace not heating bedrooms. Bleed pipes?
Hello. I have a gas furnace with baseboard hot water heat.
Two upstairs bedrooms do not receive any heat.
A service repair man who changed the thermocouple last week told me I
need to bleed the pipes.
There are 3 copper pipes labeled bedrooms, living area and basement.
The pipes are threaded and have off/on valves. The pipe marked bedrooms is cold; the other two are warm. I attached a hose to the bedroom pipe and let water drain (approx. 4 cups all cold.) This took a few hours. Turned pipe off and heat on with no success.
Still no heat to the bedrooms.
Please advise..
Thank you very much.
Sally May is offline   Reply With Quote
Old 11-30-2010, 05:04 PM   #2
Rewards Points: 266
Your hydronic registers should have a bleeder valve on them. They typically have a small wide set flat head screw. In other words you could fit a dime into the slot to turn them but use a large screwdriver. When you open them up you will hear arir escape and keep them open until water squirts out a steady stream. A word of caution with these is they don't always close completely without some messing around. The air gets trapped in the loop above the point where you are trying to bleed the pipes.
Why did the repairman not bleed your registers as he was servicing the thermocoupler? This is a small courtesy that does not cost them a lot of time or effort. At the very least he should have showed you where the bleeders were located.
Jim F is online now   Reply With Quote
Old 11-30-2010, 09:00 PM   #3
Do your bedrooms have their own thermostats? If they do, you will need to check to see if Zone valves are working. Zone valves look like small silver metal boxes with brass bases and are usually located either near the boiler (furnace) or on one of the baseboard heaters. Zone valves usually have two yellow wires and two red wires and sometimes there is a small manual override lever on the side as well. Push the spring loaded manual lever to the other end and allow the spring tension to hold the manual lever in the manual position or "perch". Turn up a thermostat on a zone that you know works (Living room or basement) and see if you get heat up in the bedrooms. If so, replace your zone valve that is connected to the You can leave the ZV in the open opsition so you get some heat upstairs.
GotHeat is offline   Reply With Quote
The Following User Says Thank You to GotHeat For This Useful Post:
Tp54bigt (12-12-2010)
water leaking out heating furnace eazacon2001 HVAC 21 07-28-2014 08:15 AM
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Draining heating pipes to do work on walls RyanD Plumbing 5 06-15-2009 03:06 PM
Hot Water Heating, burst/frozen pipes, use pex etc??? diyjohn HVAC 3 11-14-2008 05:07 PM
