Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Introductions
Old 10-30-2006, 11:46 AM   #1
Flooring
Hi, I'm new on the site, and boy do I need HELP!!!
I have removed carpet from a room and found beautiful hard wood flooring. Now I need help in knowing how to remove the carpet tape that is around the edges... Dry, brittle, etc. Any suggestions would be greatly appreciated. Thanks, DR
Diane Rule is offline   Reply With Quote
Old 10-30-2006, 08:58 PM   #2
DIY'er
Flooring
I am assuming that it doesnt just "peel up" easily...Never encountered this before, as all the carpet I have ever pulled up was secured with "tack strip"..... Is it indoor/outdoor carpet that you pulled up? I removed some of that once and it had tape and it came up easily...
Maybe try a little water and a putty knife?
Doug Russell
"What if the hokey pokey really IS what its all about."
dougrus is offline   Reply With Quote
Old 11-06-2006, 11:03 AM   #3
Flooring
Thanks for the hlep. I did find a putty knife worked, and I put my hair dryer close to where I was working on the tape. It softened it just enough to keep a slow pull... Finally got it . Thanks again.
Old 11-06-2006, 11:42 AM   #4
DIY'er
Flooring
Not a problem.
Doug Russell
Old 11-07-2006, 12:59 PM   #5
Central Florida Painter
YourWayPainting's Avatar
Flooring
Welcome Dianne.
A good paint job isn't cheap. A cheap paint job isn't good.
YourWayPainting is offline   Reply With Quote
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 02:04 PM
Chlorine Resistant Flooring for Bathroom herbolaryo Flooring 7 05-22-2007 10:05 PM
Hallway Flooring jay1000 Flooring 3 05-30-2006 07:04 PM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 10:08 AM
IAQ and flooring. Briefly. Benhamcarpetguy Flooring 12 03-24-2005 09:53 PM
