First Timer! - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 01-16-2008, 08:51 PM   #1
First Timer!
Hello everyone. I'll try to keep it brief. I just purchased a 2 family home built in 1927 in Buffalo, NY. I don't know how to do anything but am willing to try. House in in good condition except for all the wallpaper....will need to know how to get it down. And there is a shared furnace that I would like to get rid of....Buffalo is too cold to be paying for someone else's heat. Are these things hard and by hard I mean on the pockets to correct? HELP ME PLEASE!!!!
ndbuffalo is offline   Reply With Quote
Old 01-16-2008, 11:30 PM   #2
That ADA Guy
Wallpaper- dawn dish washing soap diluted in water, use an old windex bottle, and a putty knife is all that is needed for the wallpaper IF it was put up within the last say 15 maybe 20 years. I have run into some of the older stuff that was more difficult, but try this first. Wet the paper down with the soap solution, wait a few minutes, then peel off the first layer. Keep applying the soap and water and keep peeling. I use a 6" drywall tape knife to scrape ( carefully) to the wall. You will have to do this several times because after the last layer you will be removing the glue too. Hope this helps.
Sorry I can't help with the HVAC, I don't know much about that one.
Jeff_of_all_Trades is offline   Reply With Quote
Old 01-24-2008, 12:28 PM   #3
Thanks for the info. I am sorry for the late reply. I just realized i had responses. I ordered a Wagner wallpaper steamer from Amazon for about $50 so, hopefully that will make it a whole lot easier.
outdoor mechanical timer problem arby Electrical 4 12-20-2007 02:48 PM
Porch lights with timer or photocell? ciera Electrical 4 10-29-2007 08:35 AM
Help with electrical timer wiring Jack417 Electrical 2 07-05-2007 03:26 PM
Adding a timer to my outdoor house lighting ConstantChange Electrical 2 03-31-2007 09:56 AM
Digital timer problems bazzer Electrical 4 11-20-2006 06:44 AM
