Electrical Power Failure - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 03-30-2012, 03:15 PM   #1
Electrical power failure
In my barn, I lose power (120 volts) as soon as I plug something in. When I unplug, the power comes back.
allen7982 is offline   Reply With Quote
Old 03-30-2012, 03:22 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
How do you know power comes back when you unplug?
Does it happen with all plugs or just one particular plug?
sublime2 is offline   Reply With Quote
Old 03-30-2012, 05:10 PM   #3
Before I plug in, I use my multi-tester. Shows 123 volts. When I plug in something, (a light or anything), voltage drops to zero. I unplug, and the voltage comes back to 123 volts.
It happens to this one particular plug. This is the only outlet in my barn.
Old 03-30-2012, 05:23 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Could possibly be a bad connection at the outlet.
loose wire or screw.
Also,are you sure the item your plugging in does in fact work.
try it in another outlet.
Old 03-30-2012, 07:43 PM   #5
No bad connection in the outlet. They're all spit-spot perfect.
Yes, it does work, I tried it in another outlet.
Old 03-30-2012, 08:09 PM   #6
Rewards Points: 13,712
As long as there just one strand of wire making contact you will still read full voltage, As soon as there's a current draw the amp's can drop to 0. Go back and check all the wiring for corrosion, or poor contacts. Something as simple as a loose connection can cause this.
Old 03-30-2012, 09:11 PM   #7
Ok, thanks for the info. My barn is 700 feet away from my house, that's where the power comes from. The wire is buried underground, over 700 feet of wire. Guess I'll have to bury a new wire from the house to the barn.
Old 03-30-2012, 09:49 PM   #8
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
It would be cheaper and less time and energy to call an electrician out.
700 ft of buried wire is ALOT. would hate to do all that digging and find out it was the outlet.
The Following User Says Thank You to sublime2 For This Useful Post:
allen7982 (03-31-2012)
Power strip hack salex Electrical 3 01-31-2012 06:10 AM
Electrical Outlets with Very Low Power goph27 Electrical 6 01-28-2011 08:26 AM
Electrical Short - No Power Now Diggyj Electrical 8 01-03-2011 09:59 PM
Strange electrical power situation Richo Electrical 8 12-11-2008 07:06 AM
Do electrical breakers lose power? Patti Electrical 8 03-16-2008 12:08 PM
