| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Installing Gas Stove Pipe Fittings
by Expert Village
Ok, so now we have the threads coated with Pipe Joint Compound, and making sure there are no pieces on the interior and also that our, our female threads are clear. Which I'm pointing out here. These are the male threads, these are the female threads... Read More »
How to Take Copper Pipes Apart
by eHow.com
Taking copper pipes apart may be necessary if you're remodeling an older home or if you have a leak between a pipe and a fitting. It's a job the home handyman can handle with the right tools. Just follow the steps below. Read More »
How to Refurbish an Old Stove
by eHow.com
Restoring an old stove is a big project. Refurbishing this appliance from scratch requires a lot of time and some expense. Learn about the internal workings of a stove and gain an understanding of the mechanics of a stove to facilitate the refurbishment. Read More »
The PH Potential of Hydrogen in Water
by Expert Village
I would like to talk to you just a minute about PH, which is potential of hydrogen with the water so you can what that means to you. PH is measured on a scale of 0 to 14, 7 is neutral and ideal. Anything that is less than 7 would be known as acidic water... Read More »
How to Inspect Plumbing Before Buying a Home
by eHow.com
Before you buy a house, it is a good idea to either inspect it yourself or hire a professional to do it for you. If you do not know what to look for, you may end up with repairs and problems you did not expect. Here are some tips on how to inspect... Read More »
