Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Introductions
Old 09-23-2011, 12:12 PM   #1
Caulking baseboards to tile floor
I have read several things about caulking baseboards to tile floor. the contractor from hell that we used put the baseboards down first and then the floor. We have decided to caulk the baseboards to the tile. My question is: Specifically, what caulk to use, brand, type, etcl. There are so many I just don't know which one.
Thanks.
sandsp is offline   Reply With Quote
Old 09-23-2011, 12:19 PM   #2
Msradell's Avatar
Many of the grout manufacturers make caulking that exactly matches the grout. That would certainly be the best if you know where the grout came from.
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
sandsp (09-23-2011)
Old 09-23-2011, 12:32 PM   #3
So, you think I should match the grout and not the baseboards? The baseboards are white. Will tile caulk stick well to wood? Thanks
Old 09-23-2011, 12:35 PM   #4
Msradell's Avatar
Since the area you are filling is horizontal you want to use the color of the horizontal surface. Tile caulking will match in to fill the gap, it will bind to the wood and the waterproof.
Old 09-23-2011, 05:11 PM   #5
m1951mm's Avatar
I just finished my own bath and first laid the ceramic then installed the baseboards. There are a few small gaps here and there that I caulked. I used a very high end caulk, Accura made by Tower Sealants. It is 100 percent acrylic adhesive sealant which is paintable. I wanted a GOOD paintable caulk since I painted it along with the baseboards. Will get a pic and post how it came out. Just do not buy any of the caulks from the big box stores for your purpose. Go to a Real paint store or tile store and pay atleast $6 or more per tube. It does make a BIG difference.
If your gaps are to large consider putting in shoe moulding. Large caulk lines unless you are good at it look bad and tend to collect dirt. The shoe will span the gap and you will have a much nicer finish product.
Mickey
Fantasy Walls and Windows
m1951mm is offline   Reply With Quote
Old 09-23-2011, 05:17 PM   #6
Tileguy
Bud Cline's Avatar
BALONEY!
The caulks intended for use with tile (color-matched and sanded and unsanded) and that are sold in the tile department of a big box store are the same caulks that are sold in "real" tile stores. And they cost six dollars per tube if what you pay is to determine quality and it isn't these days.
Old 09-23-2011, 05:30 PM   #7
m1951mm's Avatar
[quote=Bud Cline;734679]BALONEY!
Sorry, You are right Bud. Forgot about the caulks in the tile dept. Was thinking only what you can find in the painting dept.
You sure are a tuff one.
Mickey
Old 09-24-2011, 05:15 AM   #8
paper hanger and painter
chrisn's Avatar
Thanks.
Really?, wow
Old 09-24-2011, 05:17 AM   #9
chrisn's Avatar
[quote=m1951mm;734687]
Originally Posted by Bud Cline View Post
BALONEY!
Wow, you got off easy with just baloney, he could have said bull cookies or worse
Old 10-02-2011, 07:18 PM   #10
Xtreme DIY'r
Welcome to the Site !
Old 10-02-2011, 07:23 PM   #11
Tileguy
Bud Cline's Avatar
Actually it's: BULL DROPPINGS!
Bull Cookies would be reserved for the Cooking Forum.
Installing floor tile but don't want grout gap to turn black overtime gatorade Flooring 4 02-07-2011 12:13 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 06:58 AM
Tile over existing tile floor? dwalls32 Remodeling 3 07-03-2007 05:19 PM
Kiwi tile for woodshop floor? rbh Flooring 2 08-20-2006 04:44 PM
