Bathroom Venting To Chimney?? - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 09-05-2010, 04:59 PM   #1
Question
bathroom venting to chimney??
Hi everyone,
I live in an old house (built 1911) in Winnipeg, Canada. The bathroom is getting very damp from the shower and I would like to install a fan. Interesting, there is a hole in the ceiling, above the toilet and sink. The hole is countersunk in the plastic and measure about 3 inches in diameter. So, I figured, hey - here's a great place to cut away for a vent (didn't do that yet - still planning).
I have an un-developed attic that is full of blown-in insulation. Just went up there to see where the hole leads. And there is a metal pipe attached to it, running to the chimney, I think. The pipe looks about the same diameter as the hole.
It's not easy to get around in the attic because most of the floorboards were ripped out and the insulation is tough to work around.
But my question is this - should I try to work with the existing hole/pipe/chimney and attach a fan to it or should a scrap the whole thing and vent anew?
The chimney is on the west side of the house, and I read that venting should go to the north or east sides only.
Any suggestions would be greatly appreciated.
-Trying Handy
Trying Handy is offline   Reply With Quote
Old 09-05-2010, 05:04 PM   #2
How far away is the chimney ?
Does the vent go into the main chimney (for fires or other) ?
...or a 2nd pipe only for the bath exhaust ?
Old 09-05-2010, 05:28 PM   #3
pipe and chimney
It's really hard to get at it in the attic, but from what I can tell the pipe stretches about 6 foot to the chimney. The chimney is not used for much except I think the water heater in the basement is attached to it (I remember hearing that from the installer).
Actually, the chimney looks kind of scary from the outside, almost like it's going to topple one day. As far as I know, there is nothing else being used by the chimney. No fireplace.
Old 09-05-2010, 06:07 PM   #4
If the chimney only has single stack & is being used by the water heater..gas ?
Then it can't be used by the bathroom vent
If there are 2 exhaust stacks & the bath & water heater are venting into seperate stacks then you are OK
My chimney has 3 seperate stacks/exhausts:
Oil burner
Fireplace
3rd - unknown
Old 09-05-2010, 08:02 PM   #5
Thank you for the reply. How does one go about checking the number of exhausts in the chimney?
Old 09-05-2010, 08:38 PM   #6
I actually went on my roof
But I have a door to the roof & its not steep
Old 09-06-2010, 11:08 PM   #7
I'm not sure if the hot water heater is gas, but I think it is.
I can understand how that would not be good to mix with other. But the pipe in the attic leads directly to the chimney - is it possible that this is unsafe as it is without a ventilation fan?
Old 09-07-2010, 07:35 AM   #8
If its gas hot water & its tapped into the same exhaust as the bathroom it could be dangerous
CO/exhuast could go into the bathroom if there is any downward pressure on the chimney
Not sure how likely that is
Old 09-07-2010, 09:01 PM   #9
Registered User
Rewards Points: 526
Don't use your chimney for the bath fan exhaust.
Ducting (including enclosed stud bays or joist cavities used to transport air), installed outside the
conditioned space have all seams and joints, both longitudinal and transverse, sealed. (M1601.3.1 &
WSEC 503.10.2)
􀂉 Flex duct supported per manufacturer’s specifications. (M1601.3.2)
􀂉 Metal duct minimum support every 10’. (M1601.3.2)
Insulate exhaust vent ducts with R-4 in unconditioned spaces such as attics and crawlspaces. (VIAQ
302.2.3)
IMC § 501.2: Exhaust Systems/Independent System Required. Mechanical exhaust systems for bathrooms must be independent of other exhaust systems.
Check on these for your local area with your Building Department.
Gary
Venting a bathroom Cossack Plumbing 10 06-27-2010 03:07 PM
Venting up vs out for bathroom, kitchen pcampbell HVAC 12 11-15-2008 10:02 AM
Venting bathroom vent thru dryer duct jredrocker HVAC 2 09-27-2008 10:25 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
Venting my bathroom - Should this be done? fjacky HVAC 14 08-23-2007 02:10 PM
