Basement Stairs - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 09-06-2009, 02:36 PM   #1
Basement stairs
I'm contemplating remodeling the basement, but I'll need to either turn or relocate the stairs. Is this a do-it-yourself project or should I seek professional carpenters.
sanderson is offline   Reply With Quote
Old 09-06-2009, 04:47 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
If you feel comfortable I can't see why not, just make sure you check the codes as there are specific requirements such as the maximum height of a stair and minimum width, etc... Also the clearance before you bump your head needs to be a certain amount. This probably varies by region.
I want to do mine eventually, I found this online which explains stairs quite well:
http://www.extremehowto.com/xh/artic...ticle_id=60182
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 09:24 PM
water comes down basement walkout stairs carriepartlan Building & Construction 1 07-09-2009 06:13 PM
Concrete Basement Stairs thomasd333 Building & Construction 2 12-26-2008 04:49 PM
