2 Yr. Pool Liner Has Wrinkle On Bottom HELP - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 09-10-2010, 12:13 PM   #1
2 yr. pool liner has wrinkle on bottom HELP
30 years, no problems. Installed a new liner 2.5 years ago and now it has a 1" sagging wrinkle on bottom of the shallow end, right before deep end. You can see it stretching/slipping from the bottom corners...upon installation they put foam on bottom to "try" to smooth it out, but the texture looks terrible! Had plumber out today to unplug a clogged drain, which is what the pool guy suspected...water undernieth, but we wonder if it's really an issue of poor installation, or because it's sliding on the foam on the bottom... please HELP!!!
Tric is offline   Reply With Quote
Pool parts...what is this for? tripflex Plumbing 5 02-17-2012 06:32 AM
Intex Pool goes underground arbizval Building & Construction 5 06-05-2011 08:34 AM
Swimming Pool subpanel tedpoppke Electrical 3 08-24-2010 08:59 AM
Pool liner installation?? elscorcho General DIY Discussions 3 06-10-2008 08:59 AM
Moles unde pool liner...causing "craters" abacuslearns Landscaping & Lawn Care 1 10-27-2007 07:37 AM
