1st Timer - Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Introductions
Old 12-08-2006, 08:43 AM   #1
1st timer
Hi,I just joined,I'm a licensed HVAC contractor, and Home Builder.
PATMAN is offline   Reply With Quote
Old 12-08-2006, 09:08 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Hi Patman
Welcome aboard.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 12-08-2006, 10:26 AM   #3
Hi Patman,
1st question for you then:
is it usual for people to wrap the heat supply trunk with those shinely insulation before the complete the basement renovation,...i.e.drywalling around the trunk...
I am doing it right now... although keep questioning in my mind whether this is necessary... you know I got to spend money/effort on this... I know it does good rather than harm anyway... and that is why I am doing it... but would like to hear what do you think about it...
KUIPORNG is offline   Reply With Quote
Old 12-08-2006, 10:54 AM   #4
Yes, if you have central cooling. this is the vapor barrier. the duct will sweat without it and ruin your ceiling.
Old 12-08-2006, 11:03 AM   #5
Thanks for the confirmation... I feel much better now knowing that my effort has a good reason...
Old 12-08-2006, 12:42 PM   #6
yummy mummy's Avatar
Rewards Points: 1,016
patman or kui****g
I just happen to be reading this information and I also will eventually be drywalling around a central cooling duct in my basement.
What type of insulation do I need to put around it?
And how do I adhere it?
I presently am building a soffit around it.
Is there anything that I should be doing now?
yummy mummy is offline   Reply With Quote
Old 12-08-2006, 12:51 PM   #7
yes do it before you built the soffit is easier and better... in my case, I already built the soffit... it is more difficult to put the insulation on the trunk but I am still manage to be able to do it...
the instruction of the product say, you can just wrap the insulation around the trunk...
I, instead, because of the soffit, have to cut exact width length straps and slip through the soffit then tape on the trunk... which is not bad, probably save some material than above method except use more tapes..
you find the shinely tape and insulation in the insulation section in HD you see a lot of picture/instruction over there... it cost you probably around $60 for insulating all the trunk in the basement , may be a bit more...
Old 12-08-2006, 04:23 PM   #8
kui****g
Thanks for the advice.
I was just about to start on a portion of the soffit, but I now I will insulate it.
......here I go again to HD
Old 12-10-2006, 12:16 PM   #9
Central Florida Painter
YourWayPainting's Avatar
Welcome PATMAN.
A good paint job isn't cheap. A cheap paint job isn't good.
YourWayPainting is offline   Reply With Quote
Help with electrical timer wiring Jack417 Electrical 2 07-05-2007 03:26 PM
Sprinkler timer system? Proulx06 Landscaping & Lawn Care 3 06-06-2007 12:55 PM
Adding a timer to my outdoor house lighting ConstantChange Electrical 2 03-31-2007 09:56 AM
Digital timer problems bazzer Electrical 4 11-20-2006 06:44 AM
intermatic timer with submersible water pump bardos Electrical 2 09-02-2006 02:41 AM
