Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Site Help and Suggestions
Old 01-10-2011, 09:51 AM   #1
Trim Around Door
Hi
I'm installing a new 5' x 6'8" roll up storage door to put my golf cart into my shed. What is the best way to cover the exposed 2x4 door frame. The door is roll up interior and the shed has white vinyl siding.
Thank You
Garrie
garrie is offline   Reply With Quote
Old 01-10-2011, 10:08 AM   #2
Super Moderator
Trim Around Door
I like to use white PVC trim boards--Azek--no maintenance. They are a bit expensive but not having to paint it usually make up for the cost.
garrie (01-10-2011)
Old 01-10-2011, 10:20 AM   #3
firehawkmph's Avatar
Trim Around Door
Ditto on the azek. Stainless steel trim screws are available for installation, no rust or bleeding then.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
oh'mike (01-10-2011)
Paint peeling on door trim wvphysics General Discussion 5 12-09-2010 06:03 PM
Interior door trim without enough space for a whole piece Dianna Carpentry 2 05-17-2010 12:09 PM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 02:32 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 04:19 PM
