Is There A Setting On Here To Remove Ads So I Can Read The Posts? - Site Help and Suggestions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Forum Support > Site Help and Suggestions
Old 09-17-2013, 05:39 PM   #1
Rewards Points: 264
is there a setting on here to remove ads so I can read the posts?
help help
Pawl is offline   Reply With Quote
Old 09-17-2013, 05:58 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
I just remember who's ads are there and go to a different forum to not encourage the sloppy site management. I look on the space in the middle as my space and recognized the advertisers have their right, but continuing to use the site for a selling tool (# of viewers) for more ads does not make me want to continue using the site very much more if there is any inconvenience. - This also goes as far as setting my formats for certain poorly run sites/forums.
Dick
concretemasonry is offline   Reply With Quote
Old 09-17-2013, 07:24 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
Originally Posted by Pawl View Post
help help
No. They could fix it, but so far have not done so. It's been that way for a few months.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-18-2013, 05:36 AM   #4
An old Tradesmen
Rewards Points: 6,542
I run adblock, so I don't see any of the ads.
Old 09-18-2013, 10:59 AM   #5
Rewards Points: 736
What he said. It takes five seconds of your time to Google and install "AdBlock" or "AdBlock Plus" on your browser. Far more time than it took to even make this post.
Know what? I'll even do the work for you.
Safari : http://safariadblock.com/
Firefox : https://addons.mozilla.org/en-us/fir.../adblock-plus/
Chrome : https://chrome.google.com/webstore/d...ifddb?hl=en-US
IE : https://adblockplus.org/en/internet-explorer
TheBobmanNH is offline   Reply With Quote
Old 09-30-2013, 01:05 AM   #6
Registered User
Rewards Points: 5,216
Also hit "Control" and "Minus" sign a couple to read it all. Don't forget to change it back when leaving; as it is harder to read and may cause temporary neck ache- one human was hurt in this procedure.. lol. Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
BigJim (09-30-2013)
Old 09-30-2013, 08:49 AM   #7
Rewards Points: 52
Be careful using adblock. If you run a forum, it can block you out of the admin control panel.
Old 09-30-2013, 11:23 AM   #8
Rewards Points: 736
Yeah if you're gonna use one you should know how to disable certain sites / domains, and add things to your whitelist as needed.
What is the best way to remove this tiling and how much to remove? wknddiy Tiling, ceramics, marble 6 12-03-2012 10:09 PM
Setting posts for deck - Concrete Amount Question MisterSteve Concrete, Stone & Masonry 10 10-19-2012 11:29 PM
PT beams warp or twist off posts? windowguy Building & Construction 5 09-06-2012 08:24 AM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 03:55 PM
Installation of pergola posts HDelahay Landscaping & Lawn Care 13 10-11-2006 07:46 AM
