Slow Leak Under Kitchen Sink - Site Help and Suggestions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Forum Support > Site Help and Suggestions
Old 09-06-2010, 11:18 AM   #1
Slow leak under kitchen sink
We had a new sink and taps put in our kitchen a few months ago but there is a slow leak somewhere. There is definitely a leak of aome sort at the spray nozzle because it is always wet and water drips off the plastic tube even when we do not use the nozzle - actually I use it very seldom. Also, there was a very bad leak in the beginning around the tap itself - it is a one lever ball tap but I tightened the bottom of that and it seems better. For a while the water was just poouring out of this and we thought it was the whole problem. The contractor cannot be reached (surprise, surprise) and we dont want everything ruined. I can't afford another plumber if I can get away without. Please help!! Thank you
cdruet is offline   Reply With Quote
Old 09-06-2010, 12:37 PM   #2
Do all the fittings have Teflon tape on them?
byrnebox is offline   Reply With Quote
The Following User Says Thank You to byrnebox For This Useful Post:
cdruet (09-06-2010)
Old 09-06-2010, 12:43 PM   #3
slow leak
I don't see ANY tape at all - should it be visible?
Old 09-06-2010, 12:44 PM   #4
As you can see I know nothing about plumbing!
Old 09-06-2010, 12:49 PM   #5
LOL it's ok that is what this fourm is for right?
The tape might be visible, and you should probably see a little bit of white hanging out or inside the fittings themselves.
Here is what I would do if I were in your situation.
Go to the local hardware store, any one will work and pick up some teflon tape. It should be a little roll. Then turn the water off and take the fittings off 1 at a time and put the tape on them. You can find out some more details about applying the tape here http://www.ehow.com/how_5175454_apply-teflon-tape.html. Then turn the water back on and see if you still see leaks.
Sorry you have to deal with this it is bull **** when a contractor does not do there job.
cdruet (09-06-2010)
Old 09-06-2010, 01:47 PM   #6
Thank you so much. Where the sprayer goes onto the hose, do I take the nozzle off and put tape there too? This is definitely the source of part of the leak. And if I do have to take it off, does it turn or what? I appreciate your help so much
Old 09-06-2010, 08:28 PM   #7
It really depends do you know a model number of the fixture, this could also be a pressure fitting. If you do not know a model number. Can you take a picture of the fitting and post it?
New kitchen strainer leaking on Kohlr Cast-Iron sink wysiwyg6000 Plumbing 2 01-04-2010 09:47 PM
Slow leak under sink after fixing clog gunzour Plumbing 4 11-30-2009 10:27 PM
Kitchen drain leak hullabaloo2 Plumbing 4 09-02-2008 07:25 PM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 04:12 PM
stainless steel kitchen sink KANUTTER Plumbing 6 01-09-2006 04:42 AM
