News On Changes? - Site Help and Suggestions - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Forum Support > Site Help and Suggestions
Old 06-29-2013, 01:21 PM   #16
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
I hate that you are having problems Rusty, hopefully they will get it right sooner or later.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 06-30-2013, 07:28 PM   #17
An old Tradesmen
Rewards Points: 6,476
Originally Posted by rusty baker View Post
And now I am shut out again, because the "quick reply" box is gone.
Both the post reply, and quick reply work for me at CT.
Old 07-01-2013, 09:22 AM   #18
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
What I don't understand, is the total lack of response from the admins.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 07-01-2013, 01:46 PM   #19
creeper is offline   Reply With Quote
Old 07-01-2013, 11:19 PM   #20
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
Well, I don't think they are drawing a paycheck from this forum but I could be wrong, I do know the forum is FREE to join and use, so it's usually a case of don't look a gift horse in the mouth.
Updating to FF 22.0 solved the problem of the ctrl/click once again opening a link in a new tab, any other display issue might be your own settings or browser, everything here displays perfectly for me on mac FF, maybe you need to expand the browser window larger or change some preference, disable some plug-in or toolbar thing.
Also, FF has the ability to use a custom CSS template file, you'd have to check their site for detials on how to do this. it could be your default fonts or font size is doing nasty things to the display in columns etc.
RWolff is offline   Reply With Quote
Old 07-02-2013, 03:09 PM   #21
Rewards Points: 42
I am an unpaid admin on several forums. If one of my members was having a problem after an update, I would reply to the member directly and try to help. After this update, there has been a problem for many members, not just me. Working with forum software daily (but not this type) I can guarantee you that there is a glitch in the update.
Old 07-02-2013, 03:25 PM   #22
kwikfishron's Avatar
Rewards Points: 176
There was some progress made yesterday. Oversized pictures are now being re-sized automatically by the system which should solve the ads overlapping the post. It appears to have worked, at least from my screen.
As far as other issues just keep posting them here and we'll make sure to forward them to the Admin. That's about all we can do.
kwikfishron is online now   Reply With Quote
Old 07-02-2013, 08:44 PM   #23
RWolff's Avatar
Rewards Points: 502
It only affects a percentage of people actually, which to me indicates it's a browser issue, I've never had any display problems in this forum, the only issue was the usual cmd/click to open a link in a new tab suddenly stopped working, but as someone pointed out- UPDATING FF to the newer 22.0 completely solved that problem.
I don't think simply updating my FF as I did is going to fix a forum software glitch, the fact it did fix that issue tells me it's the browsers are outdated, choking on newer java or whatever code and need to be updated.
As always, when experiencing such issues, the first thing to do is try another browser, if the pages display properly in that one then you know the first browser is the problem.
The Following 2 Users Say Thank You to RWolff For This Useful Post:
BigJim (07-02-2013), TheEplumber (07-02-2013)
Pump Cast News ddawg16 Off Topic 2 05-14-2013 06:31 AM
Good news! Doc Holliday Off Topic 14 11-30-2011 07:01 AM
Sad News rusty baker Off Topic 10 07-20-2011 10:56 PM
Bad news - asbestos and a failing ceiling joist system sheslostcontrol General DIY Discussions 17 05-30-2011 12:34 PM
You know how you always see news stories about old people .... CoconutPete Off Topic 6 07-20-2010 08:06 PM
